Question about Toshiba 32AF44 32" TV
Tv starts scrolling through functions
After tv has been on a whole it starts scrolling through functions never the same some times menu, volume, changing chanels some times when you first turn it on or upto 10 min to strt acting up removed remote board and didnot help
  • Anonymous Apr 15, 2008
    scroling functions
    Genius:
  • Toshiba Master
  • 1,689 Answers
There is probably random noise or a failure of some type with the uPC area of the set that deals with the control. It is also possible that there is a fault with the control panel.
This is not going to be easy to service. There can be a lot involved. The first thing the tech will check is for the quality of the power supply distribution in the set and especialy to the uPC and control areas. If this is okay, then he will have to follow up for troubleshooting the uPC control area.
This type of repair will be time consuming and most likely very costly. You can get an estimate, but for myself I would be shopping for a new TV set because of the loss if time and the cost of the parts for a CRT set. And... I am capable myself to fix this!
Jerry G.
Posted on Apr 14, 2008
How can I get to the menu on my old rca tv/vcr combination TV without the remote
GO TV MENU - ENTER THE ITEM U WANT IF ITS TV/AV OR VIDEO CHANNEL SEARCH HIGHLIGHT AND ENTER MANUALLY BY USING THE VOLUME BUTTON AND SCROLL.BY USING THE CHANNEL UP N DOWN BUTTON ENTER BY OK OR MENU OR FUNCTION
Oct 08, 2015 | RCA Televison & Video
LG Television 32lh5000 I have started getting a problem with this TV. When I try to change the volume I press up or down on the remote control and the volume just continues to change without stopping...
Change the batteries in your remote, this is a common issue with batteries that are low on charge.
Also if you find that your TV intermitently changes channels and no one is even touching the remotethis is the same problem.
Aug 13, 2011 | Televison & Video
My tv turns on an off, and the picture and sound works fine. The problem I am having, is that no matter what button you push on the remote, or the tv itself, it just brings up the input. You could hit...
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual functions controls board that have like buttons POWER,Channels + -,Volume + -,MENU.This manual functions controls board it is shorted.
May 21, 2011 | Element Electronics ELCHW261 26 in. TV
'left' or 'volume down' function appears to be
The volume down button on front of TV is stuck down or the switch is bad.
May 02, 2010 | Televison & Video
Access the menu options manually
Press the set's Volume (+) and (-) buttons simultaneously to activate the Menu display. Use the Channel Down button to scroll to the desired menu item, then use Volume (+) or (-) to change that item, or to activate a sub-menu if any. (If in a sub-menu, again use Channel Down to reach the desired item, then Volume (+) or (-) to change its setting or value.) When finished, press Volume (+) and (-) simultaneously as needed to "back out" of the menu.
Not all set functions can be reached this way, especially a few involving numeric entry; but this will get you started. Good luck!
Jan 23, 2009 | Philips 55PW9363 55" Rear Projection...
LXI TV-menu options keep scrolling. How do we stop this?
I believe pressing the VOLUME UP and VOLUME DOWN buttons at the same time is what puts the set into demo mode. (It might be CHAN UP and CHAN DOWN at the same - been so long I'm not sure, but I think it's the volume buttons.)
Nov 08, 2008 | Televison & Video
Screen changes between color as a demo function.no signal
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Sep 24, 2008 | Gateway LCD26TV 26 in. Television
Toshiba 36a40
Double check that the Demonstration in the menu is not set to on. This will cause it to keep scrolling thru.....
Jun 10, 2008 | Toshiba 36A43 36" TV
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Toshiba 32AF44 32" TV Logo
183 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
