Question about Dell Dimension 4700 PC Desktop
Receive a drive one \error not found message
Receive a drive one error not found message after pnost, When hit f1 to ontinue keyboard does not function properly please help
  • barneslmb Dec 23, 2009
    yes if u insert a disk it will make sounds like it is starting to run, lights on front will flash and everything seems to be working and then it just stops all of a sudden
  • pwkno May 11, 2010
    It is very likely that your hard drive is broken. Can you hear any sounds coming from the hard drive?
  • 120 Answers
The keyboard has a feature (and associated button) called F-Lock. By default, when the computer boots, F-Lock is turned on. In the F-Lock mode, rather than sending the standard key commands for the function keys, the keyboard sends special alternate commands (like print for F7 and save for F8) that are configured in the iTouch program. In order to force the keyboard to send the standard function key commands, you must TURN OFF F-Lock by pressing the F-Lock button! Oh, and by the way, there are no indicator lights on the keyboard, and the F-Lock button is an always up momentary button - just like the keys on the keyboard, so there is no way to tell what state it is in, other than by pressing it and then pressing an F key to see what happens!
Posted on Dec 23, 2009
SOURCE:
Please see attached photo, this is what's
what are you trying to do ?
a bit more information might be able to help you.
IE: what are you doing when this (pop up) occurs ?
and why are striking the F1 or F2 keys ?
Computer keyboards contain keys that, when pressed on their own or in conjunction with another key, provide shortcuts to performing functions, saving time and keystrokes.
On most keyboards, these are the function, or "F," keys that run along the top of the keyboard. "F1" and "F2" are members of this group.
F1 Function Key
Pressing the "F1" function key while you are in an application will bring up the application's help file.
Pressing it when you are not in Windows Explorer or on the desktop produces the "Windows Help" file.
If you are in an application and press the "F1" button along with the Windows button, you will get the "Windows Help" file.
F1 Function Key Combined With Other Keys
"F1" can be pressed with other keys to gain a variety of results and functions.
Press "F1" and the "Shift" key to start context sensitive help, or help for the application.
Use the "F1" key with "Alt" to go to the next field in an application.
Press "F1," "Shift" and "Alt" at the same time to return to the previous field in an application.
To display the Microsoft system information, press "Ctrl," "Alt" and "F1" at the same time.
F2 Function Key Clicking on an icon on your desktop and pressing the "F2" function key will put the icon into rename mode in the same way as right-clicking on the icon and scrolling to "Rename."
F2 Function Key Combined With Other Keys
"F2" when pressed with other keys combines functions commonly found in the application "File" and "Edit" menus.
To copy selected text, highlight the text and press "Shift" with "F2."
To view a print preview of a document, press "Ctrl" with "F2" when in a document.
To save a document, press "Alt," "Shift" and "F2 together when in the application.
To choose the open file command, press "Ctrl," "Alt" and "F2."
Apr 22, 2013 | Computers & Internet
Disable f1 through f12 keys?
You are not able to disable the function keys on any laptop
Oct 14, 2012 | Gateway Computers & Internet
Emachines wireless not working
Try looking in the program list for the program that starts the wireless. Click Start/Programs and look for the program that drives the wireless and open it.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 11, 2012 | E-Machines M5312 Notebook
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
Hi when I start the computer, at the beginning i get error messages like, sata drive not found press f1 to continue press f2 to reboot, but i tried both f1 & f2 still windows doesn't start goes back to...
hi...you can try to remove the battery of your motherboard..the battery is located somewhwere in the bottom of the motherboard..it will reset you bios settings to default.
Apr 14, 2009 | Computers & Internet
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Cd drive changing
Your computer cannot find The Hard-drive Or operating System.
Your Primary Hard Drive, is reporting an error.
Try changing the Jumper setting on this From Master To slave.
( jumper is amall plastic Block ) on back of drive.
Then set your CD/DVD To Master.
Mike @ Compurepair.
Mar 14, 2008 | Audio Players & Recorders
Dell Dimension 4700 PC Desktop Logo
123 people viewed this question
Clive
Clive
Alun Cox
