Question about Nokia 6288 Cellular Phone
Transferring messages from nokia 6288 to pc
After updating my nokia 6288 software to 6.10, my pc suite can't read my stored text messages at all. It says "Error." Can I revert back to the old software version?
It would have been better if messages can be stored to the memory card, but it can't. Is there another way to transfer my messages? Via bluetooth perhaps.
PLS. HELP...i can be emailed thru
  • 270 Answers
Re: transferring messages from nokia 6288 to pc
Pc suite must be a better option .i think use the pc suite provided along withthe phone . phone software update dosent do any harm toc suite
Posted on Jan 25, 2008
0 characters
3 Points
How to transfer text messages from phone (LG P500) to PC
I have used Amacsoft Android Manager to transfer LG phone messages to computer, I think it works great. This guide would help:
How to Transfer Text Messages from LG Phone to Computer
Jan 11, 2012 | LG P500 Cell Phone
I'm using nokia 3110c i want to do software updation of my mobile & also want preserve my messages to pc but is it possible to transfer messages from pc to mobile again after software updation will it...
  • go to the link above and get nokia pc suite
  • install it and connect your nokia 3110c i
  • create a backup of your phone and update your mobile software
  • then restore it from backup all your contacts,messages,photos are preserved
if you are happy with my solution please rate me high and vote for me
Mar 16, 2011 | Nokia 3110 Cellular Phone
What is the use of ovi suite in nokia mobile?
If you are using a Nokia C3, there are many uses of that program or app.
One of which is software updating, wherein you will get your Nokia C3 phone updated to a higher firmware version, and in return, you will get the most out of your phone and will fix known issues using old firmware.Also there are certian apps for Nokia phones, that doesnt run or does not run properly on outdated firmware version.
By the way these updates are free coming from Nokia, To read more for their current update, read here
THe next thing for Ovi suite is, when installed also on a PC, connecting the C3 on a PC or computer with Ovi suite installed, has the ability to backup data(inbox messages, pictures,tones,phone book entrie) almost anything stored on your phone. You can also install application using your PC directly to the C3
Read on here at the official Nokia Ovi suite site for more details. Hope this helps Thank You for using Fixya
Jan 16, 2011 | Nokia C3 Cell Phone
I have nokia 5230 and i have set the default memory for d storage of text messages as my memory i want to backup those messages in my to do it?... nokia PC SUITE is only doing d back...
Hi,to be able to save messages the messages in memory cards, Since you said that Nokia PC suite only does backup for phone memory,i would sugest that you save the messages inside the phone memory on your PC, and transfer the messages on the memory storage device into the phone memory so that you will able to save the messages inside the PC.
After saving Possible messages,you can now transfer back the message fromyour PC back tothe phone memory.Just a suggestion.
Hope that helps.
Please don't hesitate to pass your comment.
Thanks for using fixya........
Jan 06, 2011 | Nokia 5230 Cell Phone
Connection 6288 to PC
hey me too hv 6288 and just now i updated wid 6.43 furmware...u just take ur usb cable(DKU-2 or CA53)and update ur latest nokia pc suite in dat there is a option of updating software try from pc suite ur problem will get solved but dont try to update ur phone through nokia website...u will not get success from their.
May 17, 2009 | Nokia 6280 Cellular Phone
I want to update my nokia 6288 how can i do so
there are two ways to update your phone
1. download and install nokia pc suit and connect your phone using data cable and run update phone software which is located in nokkia pc suit. this program will connect to intrnet and updates your phone.
*follow the instructions given carefully.
2.there is a provision for updating phone software through a default installed application in latest nokia handsets.
Jan 11, 2009 | Nokia 6288 Cellular Phone
Data Transfer in my phone(nokia 6288)
u have to istall the  the nokia  pc suite  to recognize the mobile
Oct 23, 2008 | Nokia 6288 Cellular Phone
Phne Hangs whne camera is turned on
Upgrade to latest version. Use Nokia Software Updater from your Nokia PC Suite.
Aug 12, 2008 | Nokia 6288 Cellular Phone
My nokia 6288
it is a problem with its software get it updated with nokia pc suite or from a Nokia Repair Shop
Apr 14, 2008 | Nokia 6288 Cellular Phone
My nokia needs to reprogram HELP plzzzzzzz!
*#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up).
Aug 17, 2007 | Nokia 6288 Cellular Phone
Nokia 6288 Cellular Phone Logo
120 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
