Question about Bravetti EK119H Electric Kettle
Displays "EE" and won't do anything
Kettle Displays "EE" and will not do anything, any reset solutions
  • 2 more comments
  • Sierra3 Feb 01, 2008
    Totally worked, but i think i'll still be returning the product because of all the negative ratings and the contact looks pretty brittle now after bending it back.
  • Anonymous Feb 04, 2008
    Kettle worked perfectly one day and the next the only button that worked was the temperature hold. Have only had this kettle for just over a month (it was a Xmas gift) and have made sure to empty it after use and unplug it. Am not comfortable with bending contacts, etc. Any other solutions?
  • shamur3 Feb 06, 2008
    I have the same problem, I got a replacement base from the manufacturer and that base didn't even work. Now they are sending back a full refund for the amount I bought it for at Canadian Tire. I think CT knew of this problem that's why they dropped the price so low before xmas. Now I don't know who to blame - Bravetti will never be trusted by me again. I did try moving the contacts and it seems to work.
  • Anonymous Feb 03, 2009
    same problem - leaking at water level monitor too
Two contacts on outer-ring of pot 1 upper, 1 lower. One of the contacts may be bent and not making contact with the rings which are on the outside of the base. Just fixed mine and it works! Problem solved.
Posted on Jan 30, 2008
I was thinking of that too but do you have any idea to make the ring of the lower part bent back ?
Posted on Oct 07, 2009
  • ptnd Oct 07, 2009
    I thought of that as well but do you have any idea to bent the ring of the power part back to how it was?
  • teaside Oct 28, 2010
    With pot upside down (empty!) you'll see two little copper tongues at the base.These are contact leads. On my own Bravetti pot, one of the leads was pushed towards inside too far. I just pulled it out with a very fine screwdriver...it popped out. I plugged the outfit and it works fine since then.
    Want a coffee?
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
Mar 27, 2018 | Haier Refrigerators
EE error code on reliOn blood pressure monitor?
Corrupt memory causes this.
Just guessing on your make and model type!
1 - Unplug the washer from power for 10 minutes to attempt to CLEAR THE CORRUPTED MEMORY on the main control board.
NOTE: You can try unplugging the washer multiple times to attempt to clear the corrupt memory. Unplugging the LG washer with the EE error code may clear the error code and no other action is required. The washer memory will be cleared or reset and the EE error code is considered fixed or repaired.
2 - If the code does not clear on the washer after unplugging it multiple times, this means the main electronic control board is faulty and needs to be removed and replaced.
3 - To be sure the main control board is the problem, run a TEST MODE if you want to continue the troubleshooting process or just replace the main control board and that will fix the EE error issue.
NOTE: How to run a TEST MODE on an LG front load washer is explained below...
4 - If you have unplugged the washer for 10 minutes and have done this multiple times and the EE code DID NOT CLEAR, you can run the TEST MODE and the EE error may come up with the FIRST PRESS OF START/PAUSE BUTTON DISPLAYS EE ERROR CODE. If this is the case,then you have a bad or faulty Main Electronic Control Board and you need to replace it.
Dec 16, 2017 | Washing Machines
Displaying "EE" Code. Does not run.
the best suggestion is to contact the manufacturer at: (877)337-3639.
Jun 19, 2014 | Haier CPN10XCJ Air Conditioner
Scale between the kettle and the base?
I don't particularly know the model of your kettle. There are so many out there. It sounds like the tank is leaking.
Some of these cleaning and descale agents are very powerful and corrosive. The cleaning solutions you are using may have eaten through the tank of the kettle! This is what it sounds like to me.
Check the recommendations in the instruction manual for cleaning this kettle model.
Jerry G.
May 04, 2012 | Kitchen Appliances - Others
When i enter 10 exp (-)2 equals, the calculator displays the result as 0.1 when it should be 0.01? why would this be happening?
The [EE] or [Exp] shortcut is the source of much grief to the students.
When you press the [Exp] 0 you are in fact entering 1.00 so
[EE] (-)1 [=] gives 0.1
[EE] (-)2 [=] gives 0.01
Thus
10[EE](-)2 is 10[x][EE](-)2 or 10[x]0.01 = 0.1
The new generation of calculators does not have the [Exp] or [EE] key. It is replaced by a key with a more explicit label [times 10 to the X]
Hope it helps.
Sep 23, 2009 | Casio FX-300MS Calculator
Does not work...displays "EE" only when pluged in.
Try contacting Bravetti/ Shark for manual or perform a european search for the manual. EE might equate to temperature sensor damaged by overheating thus the signal is being send to the microprocessor as inoperative in the firmware.
This design had no safety features for cutting off the heating element if kettle boiled dry - so if you left the kettle on without water the temperature sensor would overheat and become inoperative.
I hope this assist.
Jan 02, 2008 | Bravetti EK119H Electric Kettle
Boiling
Purchased at Canadian Tire mid December 07.....great sale....still more than I expected to spend on a kettle. EE and nothing.....same as previous customer comments.
Nov 07, 2007 | Bravetti EK119H Electric Kettle
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Bravetti EK119H Electric Kettle Logo
682 people viewed this question
Top Bravetti Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Mike
Andrew Taylor
Andrew Taylor
Are you a Bravetti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
