FixYa.com
Tags:
La Pavoni Pisa PA-35 Espresso Machine
LA PAVONI PISA (by 3 users)
posted by jct1964 on Jan 25, 2008
I have a la pavoni pisa, and have apparently blown the fuse on the power cord. I need to access the back of the machine to get to the fuse. Can you tell me how to remove the black steam control knob on the right side of the machine?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 24, 2008
I have what appears to be this same La Pavoni Pisa machine, although mine is called the "Espresso Inn", Dal 1905.  My problem:  the steam knob is slipping on it's shaft.  It feels as if the threads are stripped -- it won't tighten enough to be usable, but won't screw out to be removed and replaced.  How can I get this thing off?
Thanks for any help you can provide!  Otis
Comment by Ckimbo, posted on Mar 28, 2008
Apparently my machine ran dry and the safety tripped.
How do I reset it?
Solution #1
Not Rated (0)
Ckimbo
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 25, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
The knob should pull right off the machine.
Espresso machine parts and supplies
www.cerinicoffee.com
Can you Help with these Coffee and Espresso Makers problems?
repair to delonghi coffee maker...
hi i purchased a delonghi... Answer This...
kenmore coffee maker . press...
kenmore coffee maker 12 cup... Answer This...
Saeco Italia
I am having a problem with... Answer This...
Missing grounds basket lid?
I picked up this espresso maker... Answer This...
Finding parts for farberware...
Repair Service
Find Coffee and Esp. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
