Question about Sony PlayStation 2 (PS2) Console
When I turn on the power to the PS2, the disk tray immediately opens. I put in a disk and close it, after 2 seconds it opens again as if I hit the eject button. The tray won't stay shut.
    New Friend:
  • 63 Answers
I would check if your eject button is stuck if it is try to pull it out a little with small plyers or its the eject sensor or finally it might also have something in the way of the tray if you dropped it on accident or something it will keep opening if something is in the way. hope this helps.
Posted on Dec 23, 2009
SOURCE:
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Green Light will not stay on when I close PS2 slim tray
That sounds like a damaged wire that may be grounding out when you close the tray. Do you have the larger (older) PS2 or the slim one?
Jul 10, 2010 | Sony PlayStation 2 (PS2) Console
Ok my playstation 2 disk tray will open only half it wan't close
it is tray problem,
its easy , unscrew all, carefully open from one side(sometime u unplug the powercable) ,so slowly remove cover ,
u can see the drive on the right , there will be 4 screw remove it now u can see thadjusment
od the left side u see screw which remove the tray
rearrange the tray again and apply some oil on the runner that it then fix it, try the tray without closing
Mar 18, 2010 | Sony PlayStation 2 (PS2) Console
Disk tray opens and closes repeatedly
WHEN IT OPENZ PUT THE DISK IN ND IMMEDIATLY TAKE THE POWER PLUG OF WAIT A SEC ... RE PLUG ... RESTART THE SYSTEM AND OFF YOU GOOOOOO
Jan 18, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slim says disc tray open off and on during gameplay
you are very genious man u think so u put heavey weight on ps2 so you have to put out your cd tray than with helpo of screw driver you open your console than take a tiny thiner than put at this tray of ribbion than wash and clean our disk tray than got new rubber band and some grees and than close your console any try again inshallah you got good result
Dec 31, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Disk tray wont go in all the way
IF FOR SOME REASON THE TRAY DOES NOT OPEN, OR HALF-WAY OPENS FOLLOW THE FOLLOWING STEPS TO RE ALIGN IT.
STEP 1) TAKE THE COVER OFF, BY UNSCREWING IT FROM THE BOTTOM.
STEP 2) NOW TAKE OFF THE 4 SMALL SCREWS ON TOP OF THE CD ASSEMBLY, ONCE YOU TAKE THEM OFF THE TOP SHOULD COME OFF EASILY.
STEP 3 ) YOU SHOULD BE ABLE TO SEE THE SPINDLE AND THE LASER NOW. BEFORE YOU DO ANYTHING ELSE TURN THE PS2 ON AND HIT THE POWER BUTTON. ONCE YOU HIT THE POWER BUTTON THE SPINDLE SHOULD SPIN AND THE LASER SHOULD MOVE FOWARD AND BACKWARDS AND ALSO UP AND DOWN. IF ALL THIS HAPPENS THEN YOUR PROBLEM PROBABLY IS THE TRAY IF ONE OF THOSE THINGS DON'T MOVE THEN THATS PROBABLY YOUR PROBLEM. NOW HIT THE REST BUTTON AND SEE WHAT HAPPEN
STEP 4) IF THE TRAY IS MISALIGNED, LOOK TOWARDS THE FRONT LEFT SIDE OF THE TRAY YOU WIL SEE TWO SCREWS, TAKE THOSE OFF SO YOU CAN TAKE THE TRAY OFF.
STEP 5) ONCE THE SCREWS ARE OFF, LIFT THAT SIDE AT ABOUT A 45 DEGREE ANGLE AND PUL THE TRAY OUT.
STEP 6) BEFORE WE TRY TO REALIGN IT TURN THE POWER BACK ON AND HIT THE EJECT BUTTON, WE JUST WANT TO PROVE ALL THE GEARS AND THE MOTORS ARE WORKING. IF THEY DO MOVE THEN THE ONLY THING NEEDED IS THE REALIGNMENT. IF THE GEARS DON'T MOVE YOU PROBABALY HAVE A BAD MOTOR OR A GEAR MIGHT BE BAD
STEP 7) NOW TO REALIGN IT. MAKE SURE THE CD TRAY SLIDE, THE WHITE PIECE, IS ALL THE WAY TO THE LEFT.
STEP 8) WE ARE GOING TO SLIDE THE TRAY ALL THE WAY IN, BUT MAKE SURE ITS DONE IN A 45 DEGREE ANGLE AND THAT THE TRAY IS ONLY CONNECTED TO THE RIGHT. ONCE ITS IN ALL THE WAY LOWER THE TRAY TO THE LEFT SIDE. IF IT HITS THE PIECE IN THE BACK-LEFT PULL IT A BIT FORWARD. IT SHOULD FALL IN EASILY. NOW TURN THE PS2 ON AGAIN AND EJECT THE TRAY, HOPEFULLY IT OPENS ALL THE WAY. IF IT DIDN'T START AT STEP 5 AND START AGAIN. SOMETIMES IT TAKES 2 OR 3 TIMES TO GET IT INTO THE RIGHT PLACE. ANY Q EMAIL FELTON [email protected]
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
My xbox wont stay shut
push it in until it closes .i know it sounds crazy but it worked for my ps2. i dont know about xbox though.
Nov 13, 2007 | Microsoft Xbox 360 Console
Disk wont spin
Your, dvd playing in your ps2, may be malfunctioning, your best bet is buying a ps2 dvd player, taking the old one out, and putting the new one in, and I guarantee that that will help you continue on your massive killing rampage on vice city.
Aug 20, 2007 | Sony PlayStation 2 (PS2) Console
PS2 disk tray keeps opening
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or broken.you might need to open it up.
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
PS2 disk tray problem
This has happened to me before. You will have to open the PS2 and clean the laser which is under the tray(or on top i forgot).
Use a cotton bud to clean it but be extreamaly careful cause if you put to much pressure on the laser your PS2 is gone for good!
Jul 05, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
151 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
