Question about Samsung TXM2756 27" TV
Vertical Height Problem
The Top of the raster has several vertical retrace lines not too annoying while the picture is broadcast in 4:3 but when the pix goes to 16:9 as many sources appear to be doing, the black area (vertical blanking??) contains these retrace lines as well as some compression of the entire sweep for about .375 inches.
I am not sure if there is any foldover or not of that area at the very top of the raster. The problem is slowly getting worse over several months but I fear that I am about to lose a capacitor or vertical o p driver soon. The set has a very good picture such that I would likke to fix this little glitch. I was a TV technician for over 20 years until 1993 and sams photofacts or other manuals were a phone call away. Any assistance you can offer me in terms of schematics or other advice would be appreciated.
    Problem Solver:
  • 15 Answers
I work with electronics, too, and I don't have the exact schematics, but I would say that you are on the right track with thinking the capacitor is going bad. What put onto that idea how you mentioned that it had gotten worse over time. I don't think that it's the veritcal driver.
Posted on Jan 25, 2008
Picture up side down vertical retrace lines
Upside down picture is due to the connection reversal to vertical scan section winding at the deflection yoke.
If you wish to know more about retrace lines, and the repair work to it; visit this site. http://electronicshelponline.blogspot.com/
Reasons for retrace lines are given with illustrations.
Mar 30, 2015 | Televison & Video
Apex gt2715 vertical sweep capacitors
Check the filter capacitor to the power supply to vertical output section. Normally, this supply will be provided by LOT. Check the rectifier diode and smoothing capacitor. Replace all the electrolytic capacitors [5 or 6 of them] in the vertical output section. It will be the best remedy. Never forget to replace the supply smoothing capacitor described above.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 21, 2012 | Apex Digital AT2708S 27" TV
Daewoo dtq-206sc have retrace lines
if retrace lines at top of picture the issue is in the vertical circuit--usually a bad filter cap and or the output chip (most of the caps that cause that are 220 uf or 330 uf and connected directly to one pin on the chip.
If retrace lines are across entire screen---likely the master screen control on the Flyback is set too high--causes excessive brightness and the retrace lines.
May 22, 2012 | Daewoo DTQ-20U6SC 20" TV
NOISE LINES I THINK
Hello
These lines are calle vertical retrace lines. Try to eleimitate them by adjusting its screen control. Screen control is inside the Tv, can be located at the LOT.
Mar 02, 2012 | Sony KV-27V65 27" TV
RETRACE LINE ON SCREEN AT TOP
If you know some electronics. Then open unit and look in the vertical curcuit for bad capacitor near vertical chip. This is happens because the heat break down capacitors. Also something a little easier the vertical height is set to high. Call the manufacturer and see if a company tech can guide through the procedure.
May 18, 2011 | LG Flatron F700P 17" CRT Monitor
I WAS WATCHING MY SAMSUNG TV MODEL LN32A450C1DXZA AND WHITE LINES APPEARED ON 3/4 OF THE TOP PORTION OF THE SCREEN, HAD THE TV FOR ONLY FOUR YEARS
This fault is due to leakage of electrolytic capacitors in the vertical stage that is why top retrace lines are visible over the picture,if you are technical person check the capacitors in the vertical stage by replacing the same.
Jan 22, 2011 | Samsung Televison & Video
Verticle lines appearing near top. Reminiscent of more extensive problem a few years ago that repair man said were related to electronic equipment used nearby such as vacuum cleaner. He fixed it with...
Case 1:
If the horizontal lines are red, green or blue or white, and are slanted about 15 degrees up going left to right, they are "vertical retrace" lines. These are caused by the beam current in the offending gun being left on while the vertical deflection is retracing from the bottom to the top on its way to start drawing the next frame. The usual cause is the CRT screen setting being too high (too bright), but (rarely) it could be something wrong with the vertical blanking circuit. Since it is dependent on vertical position, I would check the power supplies feeding the vertical deflection circuit and the CRT bias voltages, especially if they share the same filter capacitor.
Case 2:
If the lines are true horizontal, and colored similarly to the picture (sometimes alternately white and colored the same as program material), the top of picture is folded over itself because of over-voltage distortion ("clipping") in the vertical drive. In this case, reducing the height of the picture also reduces the fraction of the picture with the lines, and may eliminate it. If you are unable to get a full-height picture without the lines, then you should check the vertical deflection circuit for leaky capacitors (also check the power supply voltage going to it).
Case 3:
Several times I've observed bright white lines with random interruptions at the top of a picture supplied by the local cable company. These often occur on one or a few channels for a time (once or twice I've seen it on all channels), and go away after a while. This is a glitch in the cable service.
Case 4
You have a zone of weird colors at the top of the screen. This is probably caused by magnetization of the shadow mask inside the front of the picture tube that is not being erased when the TV is first turned on. Check to see if somebody left a magnetized object on top of or above the TV (look behind the set also). If you find something remove it, turn off the TV, wait a few minutes, then turn it on again. (Explanation: the TV has an internal demagnetizing coil that operates only when you first turn it on. It uses a self-heating temperature-dependent part to gradually reduce the alternating current going through it to override and "fade out" any stray magnetism in the shadow mask.) If the internal demagnetizing (AKA degaussing) coil isn't strong enough, you'll need that "ghostbuster" gadget again. If you don't find an external magnetic source, the internal coil may have slipped out of place at the top of the picture tube and is too far away from the shadow mask, or something is wrong with the degaussing circuit.
If none of these cases match what you see, try a more detailed description of the lines and I'll give it another shot.
Nov 27, 2010 | Sony Televison & Video
Several lines run across the top of the screen
Several lines acroos the screen at the top along with picture is a typical fault. You are seeing vertical retrace lines. Either the supply smoothing capacitor to the power supply given to vertical output Ic or vertical output capacitor connected to the vertical output pin of that Ic may faulty. Usually the supply smoothing capacitor seen faulty. It may be over 1500Mfd eletrolytic capacitor used there. It may get value reduced by 40 percent or so, this falult will occur. Please replace the two capacitors together and will get the result.
Oct 15, 2010 | Toshiba 27A34 27" TV
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Lines at top of screen
I have seen issues with complaints of raster with vertical retrace lines at the top of the picture and capacitor 2494 needs to be removed.
Jul 23, 2008 | Philips 27MT3305 27" TV
Samsung TXM2756 27" TV Logo
100 people viewed this question
Jerry Greenberg
Jerry Greenberg
