Question about RCA Lyra RD2011 MP3 Player
Computer won't reconginse my mp3.
When i connect it to any other computer, there isn't a problem at all. As soon as I connect it to mine. I don't get anything. What can I do?
0 characters
1 Points
I just bought the usb connector for the sansa sandisk c150 mp3 player and my computer will not recognize it when I plug it in.
Make sure it is the right thing.
I tried to use an extension cable for
mine and It won't work with it.
I don't understand it!
No ext fine, use ext no fine.
It could be the wrong cable/connector.
Aug 13, 2011 | SanDisk Sansa c150 MP3 Player
Player is not recognized by any computers
Try downloading the software and/or drivers for it before connecting it to your pc. If you no longer have the disk that came with it - go to the manufacturers website and download them there. Don't connect it to your pc until the software is installed. The computer won't recognize it until the software and/or drivers are installed.
Apr 17, 2011 | Samsung YP-U3 MP3 Player
Coby mp605-4g will not turn on
Your Mp3 player will be dying soon . . mines did the same thing for a while but then it just died. If you want to make it mobile try plugging it in and when it comes on, Unplug the cord from the mp3 player and the computer, Then stick one end back into the Mp3 player with out it being connected to anything else and it should come on if it doesn't . . . I'm sorry about you player.
Mar 20, 2009 | Coby MP-C858 MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Help!I cant charge my Mps with the USB cable...
Ok, wich USB you are conectting? Cause if you are connectting in the front, it don´t have enought current to recharge the mp3, but wether you connect in the back USB , it will works very good. If you have a Notebook, connect in other USB until you find the correct one. I Think that i Help You, Good Luck.
Feb 05, 2009 | Sony NWZ-E438F Digital Media Player
Mine Mp3 player had 3.99 GB of capacity and after few days mine MP3 player showed me Some Disk error, so when i connected to the computer it told me to format it. So when i formatted it, it only showed...
Mine Mp3 player had 3.99 GB of capacity and after few days mine MP3 player showed me Some Disk error, so when i connected to the computer it told me to format it. So when i formatted it, it only showed 1.90 GB.
Nov 12, 2008 | LG MF-FE502 MP3 Player
Samsung Yp-T10 mp3
hi!~ I need you help.
I connected my mp3 to computer,
and opened the mp3 folder on computer,
and i'm supposed to see the system folder right?
but I couldn't find one for mine.
how do you create system folder on Samsung yp-t10?
that my problem too....
Aug 23, 2008 | Samsung YP-T10 Digital Media Player
the player has to be connected to computer via USB cord one end goes into the mp3 or mp4 and the other goes into the usb port after it has charged to turn it on u have to hold the menu button down/ Thats how mine work Does anyone know how to add videos I have added pictures which looks beautiful.
Feb 19, 2008 | iLO (2 GB) MP3 Player
Jan 08, 2008 | Philips GOGEAR SA6045 MP3 Player
Ipod freezes up computer when hooked up
uninstall itunes and the ipod software then reload everything it and if u have more then one usb slot make sure u put it back in the one u use to load it with because sometimes the computer is very picky with that. its worked for me when mine does that so maybe it will work for u
Nov 10, 2007 | Apple iPod MA446LL/A MP3 Player
RCA Lyra RD2011 MP3 Player Logo
19 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
