If you have never overdriven the speaker, it'll probably be a dry solder joint in the crossover. Take all the screws out the back panel, the crossover is mounted on that. Unscrew the crossover board, redo all the solder joints, finaly make sure the cheap spade terminals are connecting to the speaker properly, then put it all back together. You can check all the connections if you have a multimeter. Same happened to me.
