GE D52GW12 52 in. Rear Projection HDTV-Ready Television
Problem for GE D52GW12 52 in. Rear Projection HDTV-Ready Television
Same problem. I think GE need to recall this tv. It cost too much just to throw away.
By chinton on Jan 25, 2008
I had my TV for exactly 3 years (older model tv's last longer than this). My TV will not come back on. The power light turns green then you hear a sound then boom there you go, it's back off again. Any help besides throwing away $1000.00+ dollars would greatly be appreciated.
Same Problem
May 13, 2009
-   YEP SAME PROB HERE..HOWEVER I COULD GET MINE TO POWER UP AFTER 10 OR 12 TRIES....GREEN LIGHT COMES ON, THEN OUT, THEN ON, THEN OUT, THEN ON AND OUT A THIRD AND FINAL TIME, AND I WOULD HAVE TO WAIT EXACTLY 1 MINUTE TO TRY AGAIN...USUALLY AFTER 10 OR 12 TRIES IT WOULD CRACKLE AND COME ON. ITS A D52GW12 GE THOMPSON...CHASSIS ITC222 I LOVED THIS TV...BUT WITH SO MANY OF US HAVING THE SAME PROBLEM WOULDNT YOU THINK A HUGE RECALL WOULD BE IN ORDER? ANYONE KNOW POSSIBLE COST OF REPAIRS? -   IRONHORSETJ
May 07, 2009
-   Our TV finally died today - it did exactly the same thing that everyone else is complaining about regarding the power turning off and on. Does not seem like it is a random problem going by the amount of complaints posted. We got our tv in september 2004. Imagine how many more complaints there may be out there who aren't posting on this site.-   poolshark794
May 06, 2009
-   OK here is the update from me (ramakk).
I filed a case against Thomson in Fulton county GA in March. I received a response from TTE Corporation today. They have decided to contest the case requesting a court date after July 15, 2009. They claim that there was a 1 year warranty on parts and labor and I am out of luck because the problem happened long after the warranty expired.
They claim that a relatively small number of TVs have experienced this problem out of the tens of thousands manufactured by them.
I will set up a court date for the hearing. I would really appreciate it, if you all could post your experience (both with the product as well with Thomson) that I can use as evidence. I would like to establish that it is not a random failure.
Thanks
ramakk
-   ramakk885
May 02, 2009
-   My tv started sparking and the picture died. I have the GE D52GW12 the blue tube tries to come on but crackles and no picture. When this initially happened there was smoke sparks and possibly a fire. I quickly unplugged the tv. What a piece of ****. I'm never buying a GE tv again. I'm considering suing them for making something so dangerous. I called the GE support number and they said warranty is a year parts is two years and the service agent verifies it with reciept. The technical support is **** and is india. The CRT bulb was P16lxl00bmb. Piece of **** TV!!! I'm wondering how to get the fly thing. -   Guest
Apr 17, 2009
-   Hit the power button and it tries to power up twice (unsuccessfully), makes a static noise, then powers down. It started automatically turnig off and now the problem has progressed to not turning on at all.-   Guest
Best Solution
posted on Sep 01, 2008
Very Helpful)
Guest
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
I have the same exact thing that happened to mine as well. I have registered a complaint with the better business buerau and at cpsc.gov. Let's see if they can help us out on this situation
Solution #2
posted on Oct 10, 2008
Very Helpful)
Guest
Rating: 0%, 0 votes
I received a Full Refund on this television Monday, Oct 6. Just call the phone number I left.
Solution #3
posted on Feb 07, 2008
Helpful)
Jpettit
Rank: Guide
Rating: 82%, 3 votes
This problem seems to be very common. Do a search on google and you will find all sorts of stories of smoke, sparks, flames and melted plastic with these televisions. I believe this common problem with large sparks and flames warrants a recall. Report it to the Consumer Product Safety Commision.
https://www.cpsc.gov/cgibin/incident.aspx
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Sep 17, 2008
Helpful)
applefreak
Rank: Apprentice
Rating: 85%, 1 votes
***NOTICE: THESE DIRECTIONS ARE LISTED FOR INFORMATIONAL PURPOSES ONLY.  PLEASE KEEP IN MIND THAT THESE DIRECTIONS HAVE YOU WORKING WITH PARTS THAT HANDLE DANGEROUS AMOUNTS OF ELECTRICITY THAT HAS THE POTENTIAL TO CAUSE DEATH OR DAMAGE IF HANDLED IMPROPERLY.  IF YOU CHOOSE TO FOLLOW THESE DIRECTIONS, YOU WILL BE DOING SO AT YOUR OWN RISK AND IT IS IMPLIED BOTH THE PERSON WHOM POSTED THE DIRECTIONS AND FIXYA HOLD NO LIABILITY FOR INJURIES OR DAMAGES... that being said...***
For those wishing to fix this yourself (if you have the ability), my problem was solved with the replacement of 2 parts (I got a good deal on the parts too, cost me less than $50, getting the parts from a friend who has "connections").  With the help of a relative who is a technician and some research, I replaced the flyback (mine was an RCA 265409 but varies) and I also replaced the horizontal output transistor, although I'm not sure the original was damaged... (mine was a Toshiba C5588).  The flyback and the h.o.t. are both located on the first set of boards when you take the back off on a removable tray (the tray has two sets of boards, one has the input/output jacks for the television, the other one has the parts needing replacing.  In order to get the old parts out and the new parts in de-soldering/soldering experience is necessary.  There are alot of wires to disconnect also to get the board out for soldering and I recommend taking a few pictures of where everything goes before disconnecting wires (helped me out a few times when reconnecting everything).
Instructions: 1. Make sure the television is not connected to electricity... mine was unplugged for a week or two. 2. Remove the back cover and carefully remove wires from the two boards on the tray.  The flyback has a red wire and a black wire, both pull out (but is hard to do so).  After everything is disconnected from the tv, the tray unclips and slides out.  The white board will need to be removed to allow bottom access for soldering. 2. De-solder the flyback and h.o.t. and remove them from the board. With the parts out find the replacements and order them.  More instructions about flyback replacement is found at the bottom of the post. 3. Solder the new flyback and h.o.t. onto the board (be sure to put heat sync jelly on the h.o.t. to help efficiently transfer heat.  Put the white board back in the tray, slide the tray in the tv, reconnect everything and it should work (did for me, was done in time to watch the 2nd half of the Bears/Colts game).
Flyback Info: To find your flyback replacement part number you need to refer to the drawing # on the original part. Here is a link to another article on Fixya to find this (also shows pictures of the flyback): http://www.fixya.com/support/t381617-rca_d52w19byx1_itc222_know_its_flyback
Was this helpful?
Yes
No
Solution #5
posted on Jan 25, 2008
Helpful)
Slinteriors
Rank: Guru  GE Televisions & Videos  Expert
Rating: 89%, 3847 votes
What is the Chassis number for that set? It should be marked on the back next to the model numbers. Rca and GE need to be looked up by Chassis numbers. Let me know the Chassis and I should be able to give you some help.
Was this helpful?
Yes
No
Solution #6
posted on Mar 26, 2009
Very Helpful)
hause616
Rank: Apprentice
Rating: 100%, 1 votes
the power problem is the flyback is out.
Was this helpful?
Yes
No
Solution #7
posted on Sep 16, 2008
Helpful)
jrleopards
Rank: Apprentice
Rating: 96%, 15 votes
Call 866-465-7366 Ext: 3779
Thomson Inc
P.O. Box 671988
Marietta, GA
30006-0034
Make sure you have your tv model, serial numbers ready.
I am getting a total refund (taxes included) on this tv.
Was this helpful?
Yes
No
Solution #8
posted on Sep 01, 2009
Not Rated)
drichards63
Rank: Apprentice
Rating: 0%, 0 votes
No solutions here . . . Glad to hear this person got a refund with this posted info:
Thomson Inc
P.O. Box 671988
Marietta, GA
30006-0034
BUT, when I called that no., it was RCA's telephone division and I had to call 877-722-4388 to get RCA's television division which is also G.E. They would only troubleshoot which was a waste of time and tell me that it is no longer under warranty. All a complete waste of time since I knew my TV was 3 years old w/out warranty and NOT working. They said "they have no known issues with this model" at least in their department. Now we just have an expense huge box sitting in our family room with a blinking green light that won't come on anymore! So frustrating! (yeah . . . we aren't going to attempt that technical fix offered but appreciate those who can do that -- Thanks.) I'm off to the BBB and Consumer Affairs sites.
Was this helpful?
Yes
No
Solution #9
posted on Aug 19, 2009
Not Rated)
momto1
Rank: Apprentice
Rating: 0%, 0 votes
Wow! Guess we are not along in this. We just tried to turn our tv on today and it won't come on. Our local repair man said sounded like a power supply issue and would cost about $300-$400 for a rebuilt one.
After reading everyone elses post I think we will just buy a new tv.
Was this helpful?
Yes
No
Solution #10
posted on Sep 04, 2008
Not Rated)
jaybeesax
Rank: Apprentice
Rating: 0%, 0 votes
I have the same Make, Model, Chasis, and the same problem. Guess what else? I was told the same thing by the "Service Rep" on the phone. I have filed a complaint at www.cpsc.gov/cgibin/incident.aspx and also www.BBB.com
I suggest everyone does the same. How a company can sell a product they know will break down after the warranty is over is wrong!
Was this helpful?
Yes
No
Solution #11
posted on Aug 28, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Email or call the BBB and report GE
Solution #12
Not Rated)
Guest
Rating: 0%, 0 votes
Solution #13
posted on Jun 18, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
wow I have the same problem with my 3 year old ge tv must be a thing and this is a tv in a room that does not get used every day eather
Popular Solutions for GE D52GW12 52 in. Rear
Questions and Unsolved Problems for GE D52GW12 52 in. Rear
Do you recommend GE D52GW12 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
tv will try to turn on. It will cut on for a second, cut off, then cut on again and then cut off for... (More)
65 Other Users Have The Same Problem - Continued
Comment by stclair303, posted on Apr 07, 2009
same here I called 877-722-4388 looks like it will be out of my pocket to fix. please help if you can.
Comment by alokgoel, posted on Apr 04, 2009
same problem. I called the thompson but they asked to call the authorized agent at my own cost. I got this late 2004 and it is april 2009 now. I guess I will have to repair it my own cost
Comment by soulman864, posted on Apr 03, 2009
I have had this tv sitting around for months now and have called thomsan several times...boy oh boy the customer support is "amazing". I am glad to see someone take action against GE, especially after the way they brush off the claims of a defective product. If you could keep me posted on the development of the case ramakk that would be grealty appreciated thank you- James
Comment by Guest, posted on Mar 24, 2009
Hello All
I wrote to BBB and the CEO of Thomson in Indianapolis with absolutely no response about this problem. I will be filing a small claims case in Fulton County GA this week.
ramakk
Comment by Guest, posted on Mar 13, 2009
Same thing...started with sparking noises, burnt smell, now the "on" light comes on and off three times and TV doesn't start up...I guess I'll be reporting it as well
Comment by Guest, posted on Mar 10, 2009
I have the same problem. I called the number that somebody posted above (866-465-7366) and was told to call 1-877-722-4388. I gave them my model # and serial # name, phone #, address and was put on hold for a few minutes. He came back and told me that I have to call an authorized repair place to have it fixed, and that they do not cover any fee's for that. I asked about a recall or anything the company was doing since this was a big problem and he said there was nothing. Figures!! Here, pay 1000 dollars for our tv and fix it yourself in a few years cause its a crappy model!!! Thanks GE!!
Same exact problem. We purchased the tv in oct 2004 from best buy. I don't know what to do, but it seems like a waste of 1000 dollars!!
Comment by jasperjsmith, posted on Mar 05, 2009
JASPER SMITH - I have the same problem - Purchased unit in Dec of '04 from Best Buy and Tuner went bad in '07. I had it repaired undre warranty. Now in Feb of '09 the unit just shut off while watching it. When i try to turn it on then green LED lights for about 5 sec and I can hear the static as if it's about to power up. But the light goes out and the unit never powers up. I called GE and the said the power supply was discontinued July of '08. Products supposed to be supported for at least 7 years. Hmmmm. I have to do more research.
Comment by ty_lathan, posted on Feb 20, 2009
Same problem everyone else had with this model, whats going on?
Comment by kimmytw, posted on Feb 16, 2009
Same problem purchased in 2004 - on light blinks 3 times - tv doesn't come on
Comment by Guest, posted on Feb 16, 2009
Same problem here - Green light blinks 3 times with high pitched whistle - Never turns on. I called GE. They gave me a local number for repair, which has been disconnected. Guess I'll never buy Ge again!
Comment by kdsykesfl, posted on Feb 07, 2009
Same issue with mine -- green light comes on, high pitched noise, then it shuts off. Tries to turn itself on 2 more times and then it stops. Also smelled electrical smoke in the back. Purchased mine in 2004 and stopped working around Sept 2008. Picture tube went out before once during warranty period and Best Buy fixed it. Now this. Definitely a recall should be demanded.
I agree completely. We have the same problem too. Picture tube already went out once during warranty period. Now that it's between 3-4 years old and out of warranty, it has the same problem you described. Green light comes on, you hear a noise as if it's going to power up, then it shuts off. It attempts to restart 2 times on its own, but never does.
Comment by splatt1, posted on Feb 01, 2009
Another with the same exact prob. purchased Nov 2004 stopped working this week.
Comment by Guest, posted on Feb 01, 2009
I have a Thomson 32WB624 fith the ITC222 chassis. I bought it in May 2004 and it's been sat dead for about 10 mths now. Exactly the same symptoms as I've read several times below - 3 high pitched noises then nothing. Tried calling Thomson when it first occurred, but was fobbed off in the same way as many others. I've just found this site, and I can't believe how many others have had the same problem! For me, it was 1,399 Euros wasted.
Comment by dogman2, posted on Jan 26, 2009
same issue...Model # D52DW12..won't come back on...also purchased Nov 2004...This should be a recall...I have 100.00 tv sets that are as old as my kids and still work great...1000.00 set that just goes caput in a short time....way to go GE!!
Comment by Guest, posted on Jan 25, 2009
We have the "same problem".
I have many many years of Navy electronics and general TV & radio repair. I find this television to have the worst track record of any consummer electronics,owned or repaired.
The flyback was at fault and the Horizontal Oscillator was replaced as a matter of process.
Comment by ssmarsh, posted on Jan 23, 2009
Bought mine in November 2004 and this just started happening to my TV this week. I called Thomson (800-447-1700) and all they told me was to call my local authorized service rep. When I mentioned to Thomson that a quick Google search showed this seemed to be a common problem, the call center guy said they had no record of it. Nice.
Also, the extension given in a post below (866-465-7366 x3779) no longer works. It's some travel company called Ameniti.
Comment by ramakk, posted on Jan 22, 2009
I complained to BBB of Indiana. Here is their response. *************************************************************
We are concerned about the difficulty you experienced and understand the inconvenience incurred anytime a product fails to function properly.
Each product is covered by a written warranty that states the coverage for labor and parts. This warranty is fairly standard in the electronics industry and experience has shown that any defects in the materials or workmanship will show up within the warranty period. The least that we can do is refer the customer to one of our Authorized service center:
RAPID ELECTRONICS REPAIR 1690 COBB PKWY S STE C MARIETTA GA 30060 770-955-2631
I have rejected their solution and complained o BBB that they need to fix this and gurantee the repair for life because this seems to be a well known problem. I was kind of amused by the sentence that begins "the least that we can do is ...." they have obviously done the least that they can do:-(
Lets see what happens. I have also registered a complaint with US product safety commission.
Comment by jay7367, posted on Jan 21, 2009
Same Problem within three years. I think there should be a recall and GE knows this by having the same problem in same time frame. If not resolved there should be a class action, it will be very easy to win just by investigating GE's Tech Support computers database with the same problem and number of complaints.
Comment by ramakk, posted on Jan 09, 2009
I have the exact some problem. I bought this (GE D52GW12) at Best Buy in late 2004 and we have been experiencing this problem intermittently for the last two weeks and today it finally died. Per one of the suggestions, I will be calling GE / RCA / Thompson today. will keep you all posted.
Thanks.
KK
Comment by seaj5, posted on Jan 04, 2009
TV cracked, smoked and shut off. This TV was repaired under warranty after one month, took them 3 months to get it back. Now it is 3 to 4 yrs old and went out again. Mine burned up the circuit board, copper on bottom melted right where a red/blue wire connected to the circuit board.One of the pins connected to the circuit board arced, melted off and is like welded to the female connector, which goes to one of the three projectors. I think this was a bad connection, no other parts looked bad. It was close to the flyback thing I saw in other post. Can I get a new circuit board for this? When the tech repaired the first time, he said he had to repair the circuit board.I know this circuit board is not repairable.
Comment by strmnorm8277, posted on Jan 03, 2009
Same problem. TV went blank while I was watching, made electrical "snap, crackle pop" noises and bright flashes were coming from the rear of the TV. I have not tried to turn on yet after that. It appears this TV is a lemon. Anybody having luck with GE?
Comment by Guest, posted on Dec 31, 2008
Wow! I hope a lawyer-type consumer gets burned the same as all of us and can do SOMETHING. This is incredible. How can Best Buy sell us all the same GE unit from Thompson electronics without knowing that this is a piece of junk. Mine is almost 4 yrs old and has the exact same problem. I'm not sure if I'm more pissed at Best Buy or GE/Thompson. Shouldn't have to try to fix it myself or pay for it to be fixed. Anyone have any ideas?
Comment by OLEARY1967, posted on Dec 29, 2008
I also have this same piece of **** T.V. Has anybody had this fixed yet? What is everybody doing with these anchors?
Comment by Guest, posted on Dec 28, 2008
We have had the same issues. We bought the tv 4 years ago and it has died, did smelled smoke turn itself off all of it.
Comment by zip100473, posted on Dec 17, 2008
Thank God I have a PSP from Best Buy for 9 more DAYS!!! I am going to ask the Tech to junk it. I think that this is failure on the part of the manufacturer and the company that sells it. Thank God that no one has died! There is a real concern to the health and well-being of the consumer. Once I verify that this indeed is a failure of that part I am going to write the MN state attorney's office as well as my state governor and rep. This should be investigated. I think that there was some angle to sell these fast knowing that they were defective.
Comment by Guest, posted on Nov 25, 2008
Same problem, and I don't have anything big enough to take this thing to the shop. I've had it less than 2 years.
Comment by Btee402, posted on Nov 19, 2008
Called the 800 number left below and was just directed to a repair man nearby. I've reported them to BBB and strongly recommend everyone to do the same. Anybody have any advice on how to fix it myself without hurting myself. Minimal electronic experience
Comment by polyn, posted on Nov 14, 2008
SAme problem, repair guy said high voltage power supply is the problem and asking for $440 to repair. Same model number, chassis number
Comment by valsolco, posted on Nov 12, 2008
Got the same problem as most people. My chassis no is ITC 222 bought from Best Buy. We already called the number that was left by somebody here for refund. They said no refund, warranty is only for a year. Can somebody tell me what flyback part number should we get and where? Also, I would like to report them to as many agencies as possible. Please let me know where. I am really annoyed at having a TV that lasts for 3 years only.
Comment by Guest, posted on Oct 16, 2008
OH MY GOODNESS!! I have the SAME problem...please help.
Comment by plato2222, posted on Oct 13, 2008
Yup- same problem! Except the picture in the TV (D52GW12) started to stretch and the three primary colors took on a 3-D look. After turning it off and waiting, I tried it again and this is when it began to smoke and the distinct sound of crackling- much like that of a sparklier (firework) scared me enough to unplug it. Now it all it does when plugged in is light up the power button and then turn itself off approx. 10 seconds later. I've had this television only three years and it was manufactured in 12/2004. Maybe there needs to be more pressure for a recall! This is not the most inexpensive television around and I figure most people don't have the kind of funds that makes replacing a larger ticket item once every three to four years reasonable. I will NEVER purchase a GE appliance again! OH and I have every intention of asking anyone and everyone I know to do the same! For their protection! Thank God it didn't burn down my house or hurt my children!
Comment by Guest, posted on Sep 27, 2008
Same problem here, green light blinks 3 times and the TV shuts down.
Comment by tladytw, posted on Sep 07, 2008
while watching tv the set made a cracking sound and then turned off
Comment by Robanderson, posted on Sep 07, 2008
have the same problem as everyone else, I turn on my T.v. and makes a high pitch noise and than shuts itself on and off 3 times. :/
Comment by applefreak, posted on Aug 28, 2008
GE Model: D52GW12 CHASSIS NO.: ITC222 MANUFACTURED: MEXICO SEPTEMBER 2004 SERVICE NO.: D52GW12YX2 ===== No problems before.  I had noticed the alignment had started to drift (CNN News Bottomline over the years had sank 1/4 of the way below screen).  No other problems.  The night it died I attempted to turn it on, speakers made the normal thud noise, then a loud squeal from behind the TV and the power light went off.  Television didn't respond to the remote to turn back on.  I unplugged the power for 60 seconds and plugged back in... TV automatically turned itself on (as programmed) with same result.  I could visually see sparks through back vents and smell electrical smoke.
Comment by jrleopards, posted on Aug 26, 2008
Tv smells like burning wires, smoke coming out, crackles, just went out while watching. Has there been a recall for this tv? It is not even 4 yrs old yet, bought in nov 04. This is a ripoff!
Comment by Guest, posted on Aug 23, 2008
GE D52GW12 BOUGHT IT FEBUARY 1,2005 AND TODAY IS AUGUST 23,2008 AND THE TV TURNS OFF BY ITSELF
Comment by kquave, posted on Aug 20, 2008
I have the same problem as most. The TV went blank while watching it one day. Now you turn it on, hear sound, and it shuts off. It will attempt to turn itself of and on about three times. I brought it to the shop and was told the part it needed was no longer available. I have called Thompson several time, however, was basically told they could not help me because the TV is out of warranty. Any news on a recall?
Comment by mikewohlwend, posted on Aug 20, 2008
Same thing going on with mine. Model - D52GW12 chassis - ITC222
Comment by Bonziila, posted on Aug 19, 2008
I have the same Problem. When you turn the TV on It makes a squealing sound and shuts It"s self off The Model # IS D52GW12. I have owed this TV less than 4 years. I also had a warranty so the first time this had happened it was fixed, but not for long. I miss my TV
KK2681@aol.com
Comment by Smiljanic, posted on Aug 11, 2008
We have the same problem. Turn tv on, power light is green, hear a high pitch and kind of sounds like a spark, smells burnt and then it powers itself off. No picture, no sound. Unplugged it and not sure what to do at this point.
Comment by oquen2, posted on Jun 03, 2008
I HAVE THE SAME PROBLEM. WE BOUGHT OUR TV THREE YEARS AGO ,AND NOW WHEN WE TURN THE TV ON THE LIGHT GOES ON AND YOU CAN HEAR THE SOUND BUT THE SCREEN DOESN'T GO ON AND A COUPLE SECONDS LATER THE TV SHUTS OFF.
Comment by Deb Hollis, posted on May 12, 2008
When I power the TV on,there is a high pitched squeal and then it shuts off. The TV will not come on.
Comment by GVC66, posted on May 05, 2008
I just spoke with the Customer relations department for this. They dismissed this as a "unusual" problem. PLEASE CALL 1-866-465-7157 and open a case for this issue. I will follow up with filing a report with the Federal Trade Commission and my Governor, I would recommend everyone do the same. Planned obsolescence is stealing!!!! Defective equipment that can cause fires is negligent!!!
I will follow up!
Comment by GVC66, posted on May 04, 2008
Help.. I have the same issue!!! What of a recall? thing will not turn on!!!! crackles, etc. etc.
I took off the front to see inside however I have not poked around or drained the caps yet.
Glenn -
glenn_cohen@hotmail.com
Comment by ftcfm4, posted on Apr 25, 2008
I also have the D52GW2 Chassis#I ITC222. Can you please tell me where i can find the correct part# for the flyback ,and then where can i purchase the flyback .
Comment by pete3000, posted on Apr 09, 2008
Mine now has just started to do this. I removed the back of it and looks like i can get to everything, just what do i need to replace?
Comment by Guest, posted on Mar 30, 2008
same problem after 3 years my tv just died on me while i was watching it .ge needs to recall and we need to find away tomake them fix them or give us at least half our money back.
Comment by RBrake, posted on Mar 28, 2008
Had the same problem after almost exactly 3 years. Heard crackling sound and the smell of burnt electronics. Set tries 3 times to turn on and then shuts down.
RBrake
Comment by janaT, posted on Mar 27, 2008
Yes, I have the same problem. I've had the TV for just 3 years and then all of a sudden when you turn the power on, you will hear a sound on the back of the TV like little crickets or bees. The power button will go on and off a couple of times and then shuts off -- screen all black. HELP! This was an expensive TV.
Comment by PoePoe, posted on Mar 26, 2008
I'm having the same problem after two and a half years. Purchased from Best Buy. Modlel d52gw12 Chassis ITC222. TV shuts itself down.
Comment by glstockton, posted on Mar 25, 2008
I have the the same problem as Chinton, the scary part is that I could actually smell the burning part. I tried looking on-line for a "board" replacement P/N PSB-910 C016 186 144 356 11668 but I didn't have any luck.
Comment by Guest, posted on Mar 24, 2008
I have the same model tv. and same problem. I notice that the [focus and screen] part in side was on fire. the transformer maybe?
Comment by Pullmans, posted on Mar 03, 2008
My TV tries to come on and just goes back off. I took it to the repair shop and they were unable to get parts. I called Best Buy where I bought it and they came out to tell me to throw it away. They just replace those TV's because they cost more to repair than to replace. This will cost more than $1000.00 to repair if they can get parts. They have not had much luck even getting parts. I did not even have this TV for 3 years when it broke down. This is ridiculous!!!!
Comment by ktaz12, posted on Mar 01, 2008
this tv sucks.it does the same thing.flashes and sparks.it was bought in 2005.
Comment by vtrogers, posted on Feb 23, 2008
I have the same tv, same problem, same chassis number, please help! Is this a lost cause or is there hope?
Thanks!
Comment by katfish1, posted on Jan 28, 2008
My model and chassis is the same as the above. If anyone can diagnose please let me know.
Comment by appainter, posted on Jan 27, 2008
I have had the smae problem
my chassis number is ITC222
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Dallas, TX
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
