Question about Dell Inspiron 1100 Notebook
Dell Inspiron 1100 does not see new memory
I just installed two 512MB chips from Crucial. The laptop is only seeing 512MB not 1024MB. Any thoughts. I've replaced the old chips, reinstalled the new, made sure the BIOS is current. Any help would be appreciated.
  • mjc7992 Jan 25, 2008
    Did that. Both slots are working. I can get to 640mb but not 1024mb.
  • 749 Answers
Install one memory first to any of the memory slots and boot your laptop... then do the same on the other slot with the same memory.
Now do the same step to the other memory...
That is to see if any of the two memory has a problem or to see which memory slot has a problem... You should find a problem in there... that would be memory or the memory slot.
Posted on Jan 25, 2008
  • Rommel Balcita Feb 04, 2008
    First test of 1st memory, is equal to 512.
    Second test of 2nd memory, is equal to 512.
    Third test both memory, is equal to 1024MB --- both are compatible.
    Third test both memory, is equal to 640MB --- Not compatible.
    Check the speed of both memory via Internet ...
    ex. DDR400 512MD
    Type Capacity
    If one is slow then a possible reduction of memory, If both are the same then probably the limit of the motherboard is 640MB.
I want to know which memory to buy for my pc. I checked it on and it said I could upgrade to 1gb. When I looked inside the cover I saw a 256mb memory chip but could not see how many slots it...
hello, here's a part of the spec from the hp website. It looks like you've got 256mb on board memory and one expansion memory slot in which you can fit a 1024mb card, giving you a max memory of 1280mb (1024+256).
Hope this helps!
Product Name zv5410US US Product Number PR465UA#ABA Microprocessor 1.8GHz AMD™ Athlon™ 64 Processor 3000+ with PowerNow!™ Microprocessor Cache 1MB L2 Cache Memory 512MB DDR SDRAM (2 x 256MB) at 333MHz Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Video Graphics NVIDIA GeForce 4 440 Go Video Memory 64MB DDR (dedicated) Hard Drive 60GB (4200RPM) Hard Drive Diskette Drive External USB Floppy Drive available for customers via or local retailers
Jan 11, 2011 | HP Pavilion zv5410US Notebook
Toshiba sp6000 512mb sdr 133mhz chips
These are the memory modules for your notebook, any others won't work. The max is 1024mb
You need these modules:
PC133 512MB (PA3108U-1M51)
PC133 256MB (PA3086U-1M25)
PC133 128MB (PA3085U-1M12)
If the modules you've installed meet the above criteria then make sure they are seated correctly.
Bear in mind it is always possible one of the modules is defective so try them one at a time, also they are non-eec.
Jul 08, 2010 | Toshiba Satellite Pro 6000 Notebook
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Memory Upgrade problem
You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
Mar 22, 2009 | Toshiba Satellite P105-S6227 Notebook
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
512Mb - 1024Mb Memory upgrade problem
go to controlpanel -settings -hardware manager -search for new hardware. automaticaly your system as 1024mb. ok try it allthe best.
Nov 12, 2008 | Computers & Internet
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
Sep 16, 2008 | Computers & Internet
1st......Operating System?????
2nd.....Run Device manager to ascertain RAM installed
3rd.....Download Sandra Lite to find M/B specs.(Free Download)
4th.....Check if RAM is SODIMM,SDRAM,DDR,etc
5th.....Open PC case to ensure RAM slots available.
6th.....Purchase correct RAM.e.g.128MB->256MB,256MB->512MB,512MB->1024MB
Check to see if RAM slots are paired or not
If paired....2X128MB=256MB
Feb 02, 2008 | HP Pavilion MX75 17" CRT Monitor
Dell Inspiron 1100 Notebook Logo
Alun Cox
