Question about Bosch WFMC 3200 Front Load Washer
PLASTIC WINDOW IN BOSCH WASHER
My wife put adhesive XMAS Decorations on the plastic washer window, and when she tried to remove them there was much adhesive residue, and after hours of trying to clean with goof off, rubbing alcohol, etc., it is a goner. I take it it is not diffiult to replace the window? While trying to clean the window I heard some screws fall off inside......
  • gkrizman Aug 25, 2008
    My son sprayed aircraft paint remover on the window,Now we can not see anything through the window,It is lif it got burned,
    Novelist:
  • 130 Answers
Hello Greyroom, sorry to be of bad news, however if this is the WFMC model washer, the only part for that window is the entire door assy. It isn't available as parts. Since there is a 2 year part warranty on the US product, you may explain your issue to customer support at the 800 number on the machine and they may help with the part.
Posted on Feb 02, 2008
What kind of plastic is the "window" in a frigidaire front loading washer made of? Recently when my husband pulled on the semi circular plastic piece, which is part of the "window", it split, almost c
Hello Ann Calk -Unfortunately depending on which part it is exactly since there is any adhesive available to glue it back together you need to purchase the entire door panel. I would suggest contacting a professional to accurately diagnose and repair the window washer.
Sep 30, 2012 | Frigidaire FTF2140FS Front Load Washer /...
The brackets that attach to the driver's window on my son's 2003 Grand Am have broken due to forcing a frozen window. The window is no longer attached to the slide mechanisms. I am wondering...
Hello, normally just the window sashes break. this is the plastic part that is glued on the bottom of the glass. you can but these asahes at your dealer. they simply just glue on with a special glue
Sash Channel Came Off Glass; Adhesive on Glass
  1. Remove the door glass and lay it on a protected table.
  2. Mark the location of the clip with tape.
  3. Remove the adhesive with a one edge razor blade.
  4. Clean the glass with Isopropyl alcohol.
  5. Important: Install adhesive into the applicator and squeeze some adhesive out before you install the mixing tube. After the mixing tube is installed, run a test bead the length of the mixing tube to ensure a good mix.
  6. Fill the sash channel clip with adhesive.
  7. Install the clip in the marked location.
  8. Reinstall the door glass and put the glass in the full up position for 24 hours.
Cut off the bottom edge of the guide with a cut off wheel. (Refer to the illustration above.)
Using a thin flat blade putty knife and a hammer, carefully remove the plastic piece on each side of the glass. (Refer to the illustration above).
  • Clean any adhesive from the glass using a one-edge razor blade. (Refer to the illustration above).
  • Clean the glass with Isopropyl alcohol.
  • Important: Install adhesive into the applicator and squeeze some adhesive out before you install the mixing tube. After the mixing tube is installed, run a test bead the length of the mixing tube to ensure a good mix.
  • Fill the sash channel clip with adhesive.
  • Install the clip in the marked location.
  • Reinstall the door glass and put the glass in the full up position for 24 hours.
  • 22689012
    Sash, Side Door Window
    12378568 (US)
    88901676 (Canada)
    Structural Urethane Installation Adhesive
    Jun 06, 2011 | 2003 Pontiac Grand Am
    How do you replace the Driver's side power window motor on a 2001 chevy caalier
    Before replacing the motor I recommend that you verify that the switch is functioning properly. Replacing the switch is considerably easier than replacing a window motor.
    Here is a description of what to do to replace the electric motor in the driver's power window on a Chevrolet Cavalier.
    1. Remove the interior door panel. There are two screws in the arm rest and four around the sides and bottom of the panel. Disconnect the window door lock cable from the switch on the door.
    2. Remove the sound system speaker by first disconnecting the electrical cable and then removing four screws.
    3. Remove the plastic water shield. The shield is held in place with an adhesive that behaves like bubble gum. Pulling the plastic shield away from the door causes the adhesive to become stringy like bubble gum. The nice feature of this is that some adhesive adheres to the door and some to the shield so that during reassembly the shield sticks well to the door. During removal use a razor blade to cut the strings to help reduce any mess. Some of the shield was caught under the door panel armrest support so that it was necessary to cut the shield to completely. Rather than cutting the shield just folded it up and taped it to the door. Be careful of what comes in contact with the adhesive because after a few hours of contact the adhesive sticks to almost anything. It even stuck to the wax paper placed over the adhesive to keep it from attaching to anything it came in contact with while removing the window regulator/motor assembly.
    4. Remove the window glass. There are two nuts holding the window glass to the window regulator. It is easiest to have the window positioned about half way up to allow access to the two nuts. The window glass can be pulled out of the door by lifting the rear edge of the glass first.
    5. Disconnect the electrical connector from the window motor.
    6. Remove the window regulator and motor assembly. This will require an electric drill and some drill bits to drill out the 5 rivets. There are two bolts that attach part of the window regulator to the door. These need to be removed as well. Once the rivets and bolts have been removed the entire assembly (window regulator and motor) can be removed through the large opening near the rear of the door. It may not look like it will fit, but it does. The most difficult part of this repair was locating rivets to replace the rivets that are removed. Be careful to find replacement rivets that are the same length as those that were removed because at least two of the rivets could interfere with the moving parts of the window regulator if they are too long.
    7. Remove the window regulator from the motor. There are three rivets that hold the window regulator and the motor assemblies together. Remove the rivets by drilling them out. These rivets can be replaced with screws from the local hardware store if you prefer not to use rivets.
    8. Attach the new motor to the window regulator assembly using rivets or screws. Use stainless steel machine screws and nuts along with a lock washer under each nut. Choose whatever attachment method you prefer.
    9. Lubricate the window regulator with white lithium grease.
    10. Reinstall the window regulator/motor assembly in the door.
    11. Plug the electrical connector back on the window motor.
    12. Reinstall the window glass. Insert the front edge first to make this easier. Reinstall the two bolts holding the glass to the window regulator.
    13. Test the new motor by opening and closing the window to ensure that it is operating properly. If not, resolve the problem and continue.
    14. Reinstall the plastic water shield.
    15. Reconnect any electrical connections.
    16. Reinstall the sound system speaker.
    17. Reinstall the interior door panel. Remember to reconnect the power lock connector.
    The job is complete.
    Nov 24, 2010 | 2001 Chevrolet Cavalier
    I USED GOO-GONE CHEMICAL ON FRONT PLASTIC WINDOW GLASS AND FOGGED UP THE SEE THROUGH WINDOW,IS THERE ANYTHING THAT CAN BE DONE. WHAT IS THE REPLACEMENT PART # ON THIS ITEM FOR A WASHER Bosch model...
    Unfortunately, that part is not avail separately and the whole door assembly will have to be replace which is over £200. I think I'd live with the fogged door.
    Sorry!
    ps the door assembly is part no.241090
    Jul 06, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
    WINDOW WASHER CONTAINER CRACKED & LEAKING - VOLVO S70
    not that hard. you need to remove the wheel arch and its right in front of you
    Dec 02, 2009 | 1998 Volvo S70
    Removing the window crank 2004 corolla
    Hello. Yes, it is behind the washer. You need a thin hooked tool to remove it. Pull out on the handle, and press in on the door panel to see it.
    Nov 26, 2009 | 2005 Toyota Corolla
    Glue on the face
    Try using a fingernail to pick at the area--does it affect the residue? If it does, try WD-40 oil and let it soak for a little while. If not and it does seem to be etched, then try baking soda, toothpaste, or auto body rubbing compound to rub it out--this requires pressure and some elbow grease! It would seem that "goo gone" would have damaged more than the area of the sticker if it truly affected the plastic (which is probably polycarbonate type similar to modern auto headlight lenses). If the plastic were that tender, then normal washing operations would probably damage the window.
    Jul 06, 2009 | LG WM2487H Front Load Washer
    Remove bosch axxis 2060 washer motor
    Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
    May 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
    Bosch dryer nexxt 500 (wtmc3521uc) broker plastic window
    The plastic window can be repalced you dont need to get a new door...
    Just remove the door from the washing machine and undue the screws around the rim and unclp the plastic rim and you should be able to fit in a new one with no problem...
    hope it helps any questions dont hesitate to ask..
    Jan 20, 2008 | Bosch WFMC 3200 Front Load Washer
    Liquid between the plastic window of the door
    Well now the fun begins. The plastic window won't come off without breaking it. However you can seperate the door. Open the door to the stop and with a t20 torx bit remove the 4 screws that holds the door to the hinge. Then as you close the door it will come off. Lay the door on a towel with the face down. With a putty knife along the inside outer edge stating at the bottom of the door, you can divide the door in 1/2. Now you can get to the panel you want to clean. Use care when doing this as it is possible to break the door. The top (handle) of the door will be the last piece you pull out. You reassemble in reverse order.
    Jan 06, 2008 | Bosch WFMC 3200 Front Load Washer
    Bosch WFMC 3200 Front Load Washer Logo
    154 people viewed this question
    Top Bosch Washing Machines Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Carmen Mikulic
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
