Question about Canon PowerShot A80 Digital Camera
No memory card
I have 2 memory cards and no matter which card is correctly inserted into the slot the camera reads "no memory card".  Any ideas?
  • janeinspain Jan 25, 2008
    yes mine has the same problem and i think one of the pins is bent !!! help!!!! any idea's what i can do ??? i live in spain and dont know where to get it repaired !!!
  • zini Jan 27, 2008
    got the same problem, class action anyone
  • Canon Master
  • 4,738 Answers
Did you check the slot to see if any of the pins are bent?
Posted on Jan 25, 2008
Memory card will not re insert
Try to
1) check you insert it the correct way (check in manual if in doubt),
2) check there is nothing inside the memory card slot,
3) check if the card is damaged,
4) try another card.
If all this gives no result, you should take it to the shop you bought the camera and let them check.
Important not to use force here!
Good luck! :)
Apr 07, 2014 | Olympus VR310 Digital Camera
Memory card for t3 no longer feels secured in slot
The holder that holds your memory card is broken and needs to be replaced.
Apr 03, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Hp Photosmart 8150 can't read sdhc memory card
Unless the SD slot is specifically designated that it can read the new SDHC (Secure Digital High Capacity) memory card it will not read even though it plugs intop the standard SD slot.. I checked and this printer can't read the SDHC card only the standard SD card. You can buy a SDHC USB reader on ebay for a few dollars.
Nov 24, 2010 | HP Photosmart 8150 InkJet Printer
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
My camera will not accept the memory card
Hello, one thing you might want to try is to format the memory card. To do this:
-Insert the card into your computer in the correct slot
-Wait until the computer displays found new hardware/device is ready to use
-Open my computer and look for the card(usually given a drive letter of H,I,J...) On most machines, it will be under a category heading of devices with removable storage
-Right click and select format
-Normally the default settings will work fine
-Select ok/format/continue
Hope this helps
-Chris
May 01, 2009 | Kodak ZD710 Digital Camera
I inserted my memory card from camera but nothing happened.
What type of memory card do you have that your trying to insert.
Jan 15, 2009 | HP PAVILION A6230N DESKTOP PC
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
Memory card nor inserted
Three things may go wrong.....
1. the memory card slot is defective
soln -- blow into the slot to remove any dirt. if the problem persists, go to nokia care centre, its better not to lay your hands there.
2. the memory card might not be inserted the correct way
soln -- insert it the correct way or maybe wipe it with a clean cloth.
3. there might be a software problem which might be hindering the phone from reading the memory card
soln -- do a firmware reload, through nokia pc suite
Aug 17, 2008 | Nokia N72 Cellular Phone
CAMERA READS -CARD ERROR-AFTER INSERTING A NEW MEMORY CARD
First, make sure that the new memory card does not have the protect tab in the lock position. The new card must be unlocked and formatted before your camera will be able to use it. Also, make sure that the size card that you have purchased has not over shot the ability of your camera. I think that a 2 GB card is as large as you can use. Just because the card fits into the slot does not mean that the camera will address it!
Apr 20, 2008 | Vivitar ViviCam 5386 Digital Camera
Canon PowerShot A80 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
