Question about Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker
Krups water level problem
I am getting a low water alert from my krups fmf6 coffeemaker even though the resevoir is full. Any help is appreciated.
  • 1 more comment
  • cpg1959 Jan 27, 2008
    I appreciate the help. Unfortunately, the low water alert keeps the unit from making coffee. We'll be sending it back to Krups.
  • Anonymous Jun 18, 2008
    We had the same problem on our Krups FMF 5 starting about a month after we got it in Feb, 2008 Took it it to be repaired and then finally got sent a replacement after a month of that stuff. It did the same thing the first time we tried to use it. Sent that back in, and finally have a third one that we received today, June 17. Hope third times a charm. We believe that they received a bunch of bad chips and there are probably more coffee makers floating around with this same problem. Call Krups, make notes each time you call, and keep after them. Good luck!
  • shards72 Mar 01, 2009
    Same issue...and same issue with Krups Krummy Support. I got the "Sorry it's broke...send it to us at your expense and we'll give it a shot" response...Going to pitch it in the trash and get a different brand...
  • 6 Answers
I have the Krups FMF5 Gives a 'low water alarm' when it's full of water. Take a cheap multimeter from Wal-mart find which themal fuse on the heating element doesn't have continuity. Should be two of them on the unit, one on each side of the silver 'U' shaped element, They are covered in a white sleeve, with a metal retainer holding it to the element. They connect to the power wires White one and Black one going to the element. Mine was a SEFUSE rated for 214 degrees C, Less than $2.00 at Radio Shack I replaced it with a 226 degree C rated SEFUSE which is better than removing it entirely. (it is a safety fuse) I reused the old crimps holding it to the wires, Don't know if solder would hold up. Works like a charm.
Posted on Dec 11, 2009
  • 3 more comments
  • Grant Oct 20, 2011
    I had the exact same problem and resolved the issue using these steps as well. Both of my fuses were bad so it cost me 3.50 for two fuses :)
  • wayne2011 Nov 26, 2011
    Thanks for steps saved me from buying another coffee maker. Only had Krups coffee maker for 3 months. Parts: 2 fuses $3.88 from Radio Shack, time about 2 hours ( had problems getting security screws out ) Torx bit not long enough so I packed the extension with paper which allowed just enough bite to remove the screws. Krups should really not use inferior electronics.
  • turbomustang
    turbomustang Mar 17, 2013
    Same problem and same fix. Thank you so much JC1500. You just saved me $150 on a new coffee maker with a $1.79 part. Awesome!! Not everyone will have the Torx bit that is needed. You need the one with the hole in the middle.
  • B Davis Jun 29, 2013
    JC -- extremely helpful and informative comments. Job took a couple of hours, including trips to Home Depot and Radio Shack for bits and parts. Now the unit works like new. Kudos and many thanks!
  • Dan Jekic
    Dan Jekic Jun 12, 2014
    Feels great when we fix it ourselves! Wouldn't have had a clue without your help - Awesome!
  • 36 Answers
it looks like your coffee maker has a LCD display panel driven by a discrete electronic circuit board inside. similar to brita water filter which is driven by an integrated circuitry. be honest with you, many manufacturers' product designers, especially today's new generation, they only look on good and fancy side and forget about durability, yielding a lot of junk products. unless it is still covered by warranty, otherwise, don't spend good money on bad, just ignor the warning, or disable the warning if you could.
Posted on Jan 25, 2008
I had the same problem. I bought my coffee maker about 2 years ago. A few weeks before my warranty expire, I got "low water alam". I sent it for repair and they sent me a new replacement. A few days ago, it did it again. Unfortunately, Krups said my warranty expired aleady and I could send it for repairs but I have to pay for it. I think the coffee maker only has a year life span. I'll never buy Krups again!
Posted on May 10, 2010
Its the thermal detector which is secured near the water tube of the main heater/water boiler. I'm trying to get a replacement part.
Posted on Apr 26, 2008
I have a krups 12 cup coffee maker that leaks when I pour water into the resevoir. How can I fix this?
Probably providing more info that includes the model number will help someone to help you. Have you any idea how many coffeemaker models Krups have made?
Jul 16, 2017 | Krups Coffee Makers & Espresso Machines
Where is the water sensor
There are two of them mounted in the middle of your face one each side of your nose. You observe the water level with them by looking at the water level indicator on the front of the coffeemaker.
Oct 25, 2015 | Krups FME2 Coffee Maker
Water sensor indicates no water even though tank is full. Is repair possible and how?
It is probably just a calcium deposit stuck in the sensor intake. Try running a diluted vinegar solution through the full coffee making cycle. No coffee of course, and run clear water through a few times afterwards to get rid of the vinegar taste. You might need to do the vinegar a second time if the first doesn't fix it.
Oct 16, 2014 | Krups Fme4 12 Cup Glass Programmable...
How do I disable the low water warning on a Krups coffee maker?
Locate the float in the tank that is no longer floating and jam something plastic underneath it so that it will communicate to the float sensor that there is water in the tank.
Oct 13, 2014 | Krups Coffee Makers & Espresso Machines
Krups KM7000 won't make a full pot.
I have one. there is a setting on how many cup you want 4,6,8,10, or 12 cups
Oct 18, 2012 | Krups KM7000 10 cup Grind and Brew coffee...
Got this coffee maker from a buddy. had been sitting for a while,ran lots of water and 2 cycles of vineger and water though without the filter to clean out debris in resevoir. still getting quit a bit in...
You may find this a useful site in the future:
Your Instruction Booklet:
It is likely that calcified deposits are gradually breaking away as you now use the coffee maker. Is your Self Clean light flashing? Instructions on decalcification and cleaningh begin on page 5 of your booklet.
To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. For your problem, let the vinegar solution sit in the reservoir for 30 minutes to an hour before beginning the cleaning cycle.
Press the Self Clean button. When the self clean light glows, turn the coffeemaker on by pressing the ON button. The self clean light will shine steadily. The coffeemaker is now in Self Clean mode. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, the coffeemaker will shut off. Turn the coffeemaker ON to see if the Self Clean light continues to flash. If it does, turn it to OFF and then repeat the cleaning procedure with a fresh solution of vinegar and water.
If the Self Clean light no longer flashes, turn the coffeemaker to OFF and then run one cycle of fresh cold water through the unit before using the unit again to brew coffee.
If you continue to see debris, unfortnately you will have to repeat until clear.
Feb 16, 2011 | Cuisinart DCC-1200 Coffee Maker
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
How do you get the brake light to go off.
the brake light comes on the dash either when the brake fluid is low in the resevoir , the fluid level switch is bad, or when there is a pressure problem in the brake system. the brake fluid level, though, is the most common. check to make sure the brake fluid is topped off. even though it may not look low, it may be low enough to light the light.
Feb 22, 2010 | 2000 Ford Taurus
Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker Logo
2,665 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
