Question about Kitchen Ranges
GE Medallion 850 Range
I have above range, self cleaning, sealed burners. The wife latched the door to do a self clean, and it won't unlatch. I am unable to find a manual, or anything else online. Model number on the strut is J35SFT-2
  • margel Mar 16, 2008
    How to set Clock?
  • Anonymous May 21, 2009
    I have one of these too. Does anyone understand all the icons surrounding the oven dials? I can't find a manual for this anywhere. Anyone know where I can get one?
    Thanks!
    Problem Solver:
  • 12 Answers
It says it my manual that the oven won't unlatch until it has cooled down enough. At this point the red light(s) is supposed to flash.
Posted on Apr 20, 2008
  • faith shortcake
    faith shortcake Apr 20, 2008
    To set the clock:
    Electronic clock has 3 modes: display, set (flashing), and clock not displayed.
    1. Press CLOCK pad til it flashes.
    2. Press HRS + OR - PAD TO SET HOURS AND MINS + OR - pad to set minutes.
    3. Press CLOCK again. Voila!
Where my clock was on my stove a E1 F-5 came up and my oven won't work now. The top burners are working but the oven won't. We don't have a manual for troubleshooting. Can you help me?...
F5 - E1 Self clean latch will not lock
2. If door not latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlkkZwU
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlaiwL3
Sep 04, 2011 | Kitchen Ranges
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
My jmp28 range has lights and burners working, we put the range into self cleaning and left it, now the oven display is not lit, it is finished and the door is locked. Tried reseting power, did not help.
The thermal fuse for the controller board has failed. Needs to be replaced.
You can use a screwdriver to unlatch the door by reaching inside the top. You will need a flashlight to see what to push on to disengage.
Dec 01, 2009 | GE Spacemaker JMP28 Electric Kitchen Range
I have an older GE self-cleaning oven. It has an
Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
GE Medallion 850 oven self-clean instructions
how do i work the oven section i don't understand the settings
Oct 26, 2008 | Kitchen Ranges
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Stuck door latch after cleaning
door latch stuck but the door is open and i can't close the door back
Sep 29, 2008 | GE Spectra JBP78 Electric Kitchen Range
Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Jan 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
1,417 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
