Question about Toshiba Satellite A65-S1062 Notebook
TEAC DW-224E-B [CD-ROM drive]
It shows in Device Manager, My Computer. It opens and closes correctly.
It shows Fail when I run the Toshiba Diagnostics.
Basically it won't read any dvd/cd/cdr. Recent problem that occurred without any added drivers. I have uninstalled, reinstalled. There are no updated drivers available (Windows has the best one).
Any suggestions?
  • addicus Jan 25, 2008
    Thanks Tango. I really don't have another cd player to put in it.
    The diagnostic really didn't give me any other message except for fail. Terrible huh?
    I'm thinking I may have to get a new one because the device does everything except for read the disc. It recognizes the difference between a disc being in it or not as indicated when by the lights when one is inserted and the tray is closed.
    If empty the lights turn off. If it has a disc it blinks then just stays on. It doesn't even turn anymore. Boo hoo.
  • Tim Leary Jan 16, 2009
    My Toshiba Satellite dvd drive recognizes that a disc has been put in it. It tries to read it, but then a message pops up after a long wait and says "Please insert disc" while the disc is still in there. I've tried a number of types of discs. I'm running Windows Vista which has had a number of issues... Now I can't seem to play any kind of disc at all.... ugg...
    I had a previous issue with the drive where my laptop wouldn't recognize that there was a drive at all. From what I had found, it was caused from inserting some game that was like 5 years old. It was a while back, but if I remember correctly I had to erase and then add some codecs or something. I don't think it's the same issue as the laptop is still recognizing that there's a drive, but I felt it should be mentioned.
    I have a Satellite A215-S4757 PC Notebook
    Can anyone help? :o
Fail could mean a lot of things but those diagnostics (If I remember correctly) look at hardware. If you have a more concise message than just fail (I seem to remember they were) and it points at the cd/dvd first check the connection and if you happen to have an old cd player around try it...if it works and the other does not you have solved the problem. There is more to this but try this first .....FYI...if you were thinking of upgrading to a lightscribe or just wanted to have an extra CD ($10) it may be in your time interest to get one. Much more could mean anything from a bad cable to motherboard problem to....???? This is a start only....let me know....Tango
Posted on Jan 25, 2008
Teac dvd no hardware found
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 26, 2011 | Teac (DW-224E) DVD Drive
I have a TEAK DW-224E-A CD-RW/DVD-ROM combo drive in a toshiba A25-S207 Laptop computer. Everything used to work, now the DVD won't work but the CD stilll works fine. Any suggestions or solutions?
Hello sanhill665, try "Updating the Drivers"
Go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Drivers" you need. Than you'll be able to "Download the Drivers."
!Attention: The 'Part No." is a "letter off. ie: "Yours= [R] Theirs = [V]. "I will say. its 'safe' to try!"
"Please let me know if you 'need' further assistance, or the 'solution' helped?
"By posting a 'Comment" or 'Rating' the solution.
Thank you; your 'response' is important to me!"
Click here:
Mar 02, 2011 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
Completely dead, will not even try to read the disk. Device Manager says its working correctly, and the driver is correct.
First try a disk drive cleaner.
If still a problem, the only solution is to replace the drive.
Hope this helps.
Oct 15, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
Teac Dw 224E-R WONT BURN ON A DVD - Is it a DVD Writer?
hi no its only a CD RW, and not a CD/DVD-RW its just a CD writer and a dvd( rom ) only memory which means it only reads dvd's but does not write them...hope this helps
Jun 14, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
My cd rom is not reading any disc and i keep hearing a clicking sound.
Go to
1-my computer
2-then properties
3-then device manager
4-then look for your cd-rom
5-uninstall the driver (only if you have the cd-rom installation program from the manuf.) and restart your PC
If you don,t then find any conflicts in the device manager "like a yellow symbol" and if you find any try to "update driver".
Keep posting!
Feb 22, 2010 | Teac Dw 224E-R Disk Drive CD-RW / DVD-ROM...
Teac dw-224e-a dvd rom will not read dvd +r -rw data
Here's the newest driver for your burner. Go to Control Panel, then Device Manager, then click on the + symbol next to disk drives, and double click on the TEAC device. Click the Driver tab and press Update Driver, then choose the 'Let me find the driver' option, and navigate to the folder where you unzipped the file to. Double click and Install. Reboot.
For burning, I would recommend Nero, Alcohol 120% or ImgBurn.
Good luck and Season's Greetings!
Chris (ziraffa)
Nov 13, 2008 | Teac (DW-224E) DVD Drive
TEAC DW-224E dvd/cd drive
first go to device manager : right click on my computer-properties-hardware- clcik on "device manager" look for a yellow hazard asterisk, this indicates a problem, if you right click on the device and select properties, you are presented with a troubleshoot facility also a means of updating your driver.....if this fails, go to google and type in the type/number of the device and you will be able to find free drivers to download.
Nov 20, 2007 | Compaq Presario 900 /1500 Series EVO...
Teac DW-224E-c - cannot burn DVD's
The answer is what you profess. The drive can burn CD's, read CD's and also read DVD's. Everytime I try and burn a DVD I have an unrecognized drive and the properties always show no disk: The drive burns CD's ie;music, but cannot burn DVD it can only read DVD like you say!
Sep 10, 2007 | Teac DW 28E CD-RW/DVD-ROM Burner
Toshiba Satellite A65-S1062 Notebook Logo
340 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
