Question about Philips Magnavox 51MP392H Rear Projection Television
Rear projection clean mirror
How can I clean mirror in projection tv
I just cleaned my 4 year old panasonic PT47WXC43G's mirror and bulbs using alcohol free baby wipes and a microfiber cloth to dry them off. I did this because my tv started to look like crap. The picture was extremely foggy. I had incredible success doing this! Saved me about 2 grand. Now I don't have to buy a new TV now! My picture looks just like it did the day I bought the TV....If not better!
Posted on Feb 28, 2008
  • Philips Master
  • 8,617 Answers
You can get to it by removing the back panel. You also have to kind of lay down beside it and kind of twist around with your head to see what your doing. But it can be done. It helps if you take the two screw out that keeps the shelf that's around the picture tube assemblies it gives you a little more room. Don't use windex though it will streak it up bad. Just a damp soft cloth and then dry it good. Makes a big difference in picture quality.
Posted on Jan 25, 2008
  • 150 Answers
SOURCE: Location of MIrrors in projection tv
wd-52525 This is a DLP, I dont suggest taking it apart to clean anything, this is what we call a MICRO display, the imaging device is about 1" square and blown up 50X to the size of the pix you watch, anytime anyone I know has taken stuff appart where the mirror is at has ended up worse off, you say that there is dust on the mirror, what does it look like in your picture? If the spots are quarter size or so and fuzzy edges the dust is inside the lightengine and you want a factory cleanroom to service the LE, the one thing I think you can safely do is pull the lamp and check for dust on it as it can cause issues in pix, other than that I dunno what to tell you, hope this info helps.
Posted on Jul 09, 2007
  • 1153 Answers
SOURCE: Pioneer Elite PRO 710HD 64" rear projection tv
You could get the old one and have them match it up. If not try
Posted on Sep 17, 2007
  • 19 Answers
SOURCE: cleaning the INSIDE of a rear projection tv - Panasonic PT-51G35
its better to see any experts near you,its risk your tv.
Posted on Oct 30, 2007
SOURCE: Cleaning tv screen
need to know how to clean a hitachi rear projection screen tv
Posted on Apr 05, 2008
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
Posted on Jul 07, 2008
I have a hitachi 55vf820 lcd rear projection tv. How do you get the cover off to clean mirror?
Don't try that as the mirror almost never needs cleaning and MUST be cleaned with a special cleaner---leave a single fingerprint on that mirror (or a smudge) and it will stand out in the picture like a sore thumb.
Reason to clean mirror?
Apr 09, 2012 | Televison & Video
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Jun 09, 2009 | Mitsubishi WD52527 52" Projection HDTV
Cleaning mirror and how to get in there
Hello timbick45,
You want to remove the top rear panel. Remove the screws and the top, along the sides, and along the middle of your TV (from the rear). Onec that is done be very careful because the mirroe is attached to the rear panel of the TV. set the back down and with a clean cloth and a can of air remove the dust off of the mirror, use a light window cleaner, after removing the dust. To clean the bulbs just use air to blow the dust off (not not attempt to clean the bulbs with any solvent.
I hope this helps
Thank you,
Mar 30, 2009 | Toshiba 50H82 50" Rear Projection...
I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Mar 13, 2009 | Toshiba 43A10 43" Rear Projection...
Cleaning rear projection screen tv
It is very rare to have to clean the mirror. It us upside down so it does not collect dust. It does however collect nicotine if there is a smoker in the house. Some RCA mirrors are not glass and should not be touched. The lenses do get dusty and should be cleaned.
Mar 01, 2009 | RCA P52926 52" Rear Projection Television
Spider web inside tv
You need to open and clean it carefully.
  1. remove the back bottom panel
  2. Remove the top back panel (carefully the mirror is on it)
  3. Clean the mirror and the lenses (on the mirror don't use products with ammoniac) "a good tip is to use same staff to clean photographic cameras"
  4. Place back the top rear panel
  5. place back the bottom rear panel
Nov 09, 2008 | Samsung PCH521R 52" Rear Projection...
Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Mar 31, 2008 | Televison & Video
Cleaning tv screen
Mar 05, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Dark color
Have you tried polishing the projection mirror and changing the coolant in the CRTs. The mirror alone can make the picture dull. Do not use windex to clean the mirror, just a soft damp cloth then dry. You can access the mirror hrough the back panel its a bit of a reach but its do able from the rear the mirror is directly above the rear acess panel.
Jan 19, 2008 | Philips 43P8341 43" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
342 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
