Question about IBM E54 (Pearl, White) 15 in.CRT Conventional Monitor
Contrast problem my monitor IBM e54 have a problem its like the right button from the monitor automatically activates. so everytime i work contrast box appears. how can i solve this problem? thank you. Rochelle Cosico
  • 1 more comment
  • sameer_av Jul 04, 2008
    I also have a similar problem. Last month I had got it repaired by one technician but it has surfaced again. I asked that person and he told that there was something wrong with 'memory' of monitor (?????)
  • prat0m Jul 10, 2008
    I face the same issue on my E54 Black set. Further the language has changed to German/Dutch on the contrast setting screen since yesterday.
  • indranil_83 Jan 08, 2009
    i have also this problem
Halo .....
i have IBM monitor crt tipe E54, i have problem the menu display on the srceen and the bottom menu canot aktif what this problem please help me
Posted on Jul 24, 2008
  • Anonymous Jul 24, 2008
    I have the its problem IBM monitor [is] menu emerge [at] [screen/sail] and knob ngak can [in] depressing to help to assist the its solution searching
My monitor IBM e54 have a problem its like the right button from the monitor automatically activates. so everytime i work contrast box appears. how can i solve this problem?
Posted on Mar 31, 2008
6ya staff
SOURCE:
Brightness option is displayed automatically it continues to appear even if menu is not pressed
It sounds like a hardware button faults from your monitor. Maybe due to dirt inside, you can shake your monitor gently if possible.
Aug 30, 2015 | IBM E54 15" CRT Monitor
Der sir ibm e54 crt monitor display ok but osd not working
maybe he need driver for your monitor to be operational. check your device manager if your monitor didnot recognize. You will need to install the required driver software for this.
Dec 03, 2010 | IBM E54 15" CRT Monitor
Monitor problem
Hi ,
you set the Brightness manually or otherwise you will repair the monitor.
Thanks
Aug 15, 2009 | IBM E54 15" CRT Monitor
Desktop is continuing to display contrast as 100
Dear mahendra
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor botton circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.It deffinately solves your problem.
Good Luck
Fixya Customer Support
Chandrashekhar
Jul 22, 2009 | IBM E54 15" CRT Monitor
On start, monitor contrast option automatically gets activated
if nothing works and you cannot access your monitor settings via the menu button on the monitor then you have no way of correcting it. as far as i am aware the only thing you can change with the monitor from within your operating system are its resolution, refresh rate. so i think you need a knew monitor.
Apr 23, 2009 | IBM E54 15" CRT Monitor
IBM E54 CRT Monitor - Exceeds the Display Width
1. first replaced the TIP 122 fet. back side of lot.
2. change the 424j / 1600v pf.
3. IRF 630 ( after power output section )
Nov 17, 2008 | IBM E54 15" CRT Monitor
Contrast automatically increases to 100%
yes! The same problem in my monitor. The contrast of my PC monitor increases automatically to 100%.If I try to reduce it,it increases again.
Oct 19, 2008 | IBM E54 15" CRT Monitor
Monitor ibm e54 coloure bluish background
please upgrade your graphics card if the problem still occurs then upgrade your os drivers...
Jan 01, 2008 | IBM E54 15" CRT Monitor
Open Questions:
See all IBM E54 (Pearl, White) 15 in.CRT Conventional Questions
IBM E54 (Pearl, White) 15 in.CRT Conventional Monitor Logo
345 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
