Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Keeps running When I turn the machine on it used to run for a few seconds then pause. Now the thing keeps running and will not pause to allow a print. I have discovered that lifting the front of the thing up at a 45 degree angle makes it pause and ready to accept a print. It may work fine then for one or 2 times then again continues to run. Is there a switch or something that isn't getting activated?
  • 167 Answers
:) No there is no switch!!! Try to get out toner cartridge shake it well!!! Turn printer on without cartridge! See the USB or LPT connection are OK!!! It's Fuser who make this problem or his sensor!! When you turn printer on he must reach 180C. Because of that printer is checking so long!
Posted on Jan 25, 2008
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
Fuel line keeps stallingoit after a few seconds
By your question, I assume that the fuel line runs dry after the engine runs a few seconds. The first thing to check is for a plugged fuel filter in the tank and the condition of the connecting fuel lines for rot, hardness, or cracking. If the machine has a primer bulb, does it pump fuel into it after several pumps? Remove the line from the primer that goes back to the tank to make sure it is pumping fuel from the carburetor only. If you replaced any lines, they may have been reconnected incorrectly. Hope this answers your question!
Apr 21, 2010 | Garden
My gaggia titanium keeps coming up with ventilate in the display have cleaned the whole machine out made no difference
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Apr 19, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
Won't shut off machine turns off after a few seconds
You may have a burnt motor. This is usually caused by a clog in the pump. Sometimes small items such as socks find its way to the pump. It could also be the timer itself. If there is a burning smell when that happend it is probably the motor.
Jun 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hi, my machine starts for a few seconds then stops and pause button wont stop flashing, have tried turning off and on but same thig keeps happenig, please help x
if it is a HE kind of machine it is supposed to stop and start a bunch of times at the beginning of the cleaning cycle. Did you wait for a while to see if it ends up running the cleaning cycle?
the new machines are kind of freaky the way they work.
later
Apr 09, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't Star keeps flashing Pause and Err
that was just happening a few seconds ago with mine and i just tried pusing the control button and the options button at the same time for a few seconds... i reopened the door and pressed start again...it's running now... good luck
Apr 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
59 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
