Question about Cuisinart DCC-100 Coffee Maker
Re:Filter dont know where to buy filter, i cant use my cuisinart dcc-100 coffee maker, not aware of you service parts here in the phils.
  • tweety_3_51 Jan 27, 2008
    the product is nice but hard to find replacement parts here in the phils.
  • ChemTeacher May 11, 2010
    Is it the brew basket (with the little valve on the bottom)?
  • 8,596 Answers
Cuisinart has the filter basket on the website and via phone.
Posted on Feb 06, 2009
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Machine shuts off during brewing
Hello bean_54806,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, bean. Positive feedback is appreciated. Good luck. NormanZ
Jul 08, 2009 | Cuisinart DCC490SA Coffee Maker
Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it, but most people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
Apr 01, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee maker doesn't turn on when you flip the switch.
Hello evc622,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, evc. Positive feedback is appreciated. Good luck. NormanZ
Mar 27, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Water filters
Cuisinart does sell them. You will have to call the Canadian line or go to www.cuisinart.ca
Oct 13, 2007 | Cuisinart DCC-2200 14-Cup Coffee Maker
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Buy new coffee jug?
Replacemet pots for the DCC-KE12 coffee makers is Cuisinart DCC-1200PRC 12 cup replacement pot.
May 03, 2007 | Kenmore DCC-KE12 Coffee Maker
Cuisinart DCC-100 Coffee Maker Logo
87 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
