Question about Jenn-Air JED8430 Electric Cooktop
Fan The fan turned on and will not turn off. I have turned it to the off position, but it stays on.
  • Joe Yetzer Feb 24, 2008
    My model looks like JED8430 but I can't find the model # on the unit itself.
    The fan just came on by itself, I tried to remove the switch by removing the
    top two screws and the two on the side but the plate doesn't want to come
    out. I'm sure it probably needs a new switch, any suggestions?
  • 770 Answers
I have had those pop up switches go bad shut down the breaker to the unit and pwr up if it is still on the switch will need to be replaced (as long as all the burners are cool)
Posted on Jan 25, 2008
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
Fisher & Paykel Thyme main oven not working
You could try reseting the clock to the manual position.
If in Automatic the oven won't turn on until set time.
Mar 18, 2013 | GE JB870 30" Free-Standing Electric Double...
The blower won't turn off on the grill side of the stove. I changed the switch but the blower stays on.
Since I don't know your model number, I will have to give you deneric advise. Some fans have a thermostat that will activate the fan when certain temperatures are met. If yours is like that, then the thermostat could be the cause.
Jul 05, 2011 | Jenn-Air Cooktops
When you turn on any burner on the spark igniter will stay on after the burner is lit and the knob is turn from the lite position.
You could of possible got the stove top wet causing the problem.This problem although sounds like your spark ignitor module went bad.
Feb 10, 2011 | GE 30 in. JGP328 Gas Cooktop
LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Oven wont turn off i unpluged it last night and it turned back on this morning when i pluged it back in
If you have turned the on/off switch to off and the oven stays on then the on/off switch contacts have fused together inside the switch.
If it were the thermostat it would get hot but would shut down in the off position
You need a need switch as simple as that
Jun 04, 2009 | Cooktops
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
Raised vent system won't stay in down position
sounds like yo u have a faulty home switch. when dropped to lowest setting it should switch off electric. however if switch is bad never senses its down adn thenwants to open back up. there should be an acces panel in lower right corner of unit along witha wire diargam
Mar 08, 2008 | Cooktops
Jenn-Air JED8430 Electric Cooktop Logo
224 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
