Question about HP Photosmart 2610 All-In-One InkJet Printer
Paper keeps feeding
The printer has been working great for three years and out of know were it started feeding one sheet after another. It will keep feeding sheets of paper until it is out of paper till it runs out of paper and it tells me to load more paper.
Scott
  • s_kostuch Jan 29, 2008
    Thanks for the feed back but I had it fixed before the help came. However I do believe it was a virus?
Just started happening yesterday to my HP printer as well....a virus maybe?
Posted on Jan 26, 2008
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
Printer paper feed
Hi there
This hapens a lot with different printers, best way is to gave your papers a good shake and keep in a worm place then it may work for you.
All The Best Pineworks
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper does not feed
Take it apart and clean the roller assembly.
Fan the paper stack before placing it in the tray.
Insert about 25 sheets at a time
Apr 15, 2009 | Dell Office Equipment & Supplies
Printer feeds in 2 or 3 sheets of paper at a time and then jams
Dears eveenz,
It seems that paper feed roller of your printer is broken. This part is integrated in drive assy. You need to replace drive assy of the printer in order to feed the paper properly. I plan to discuss this topic at Inkjet Printer Forum since I cannot post image more than 150 kb here. Explanation with image will make you know more easily. Please send me your mail to ijxpert@gmail.com so I can contact you as soon as I finish my post there.
Please rate me when you find this answer be useful for you
Regards,
Nov 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jam
Carefully remove the paper tray and the paper. The sheet(s) that are stuck can then be firmly but gently pulled backwards out of the feed input.
To avoid the problem check these possible solutions.
1 The paper itself. Check that the paper tray is not overfull. this can cause multiple sheets to feed through. Also make sure that you use good quality paper suitable for the particular type of printer. Always keep the paper dry Damp (not wet) paper will also cause the sort of problem you describe. another good reason for not keeping to much paper in the paper tray. Paper will keep better in the packet than in the tray. Always store the paper in the packet in a warm dry place. I keep mine near a radiator and away from the Air con.
2. The printer driver. Download the latest driver for your printer from the manufacturer and update the printer driver, via the control panel/printers. If you don't know how to do this you can simply uninstall the printer and then install it again using the new printer driver.
Good Luck
Carrieone
Jul 23, 2008 | Lexmark X7170 All-In-One InkJet Printer
Printer won't feed paper
Your paper is with excess of moisture. Try to keep the paper in a peper dryer, and do not use to leave the sheets not used in the printer, keep them in a dryer, or a dry place.
May 02, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Mar 23, 2008 | Brother HL-2040 Laser Printer
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
101 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
