Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Key chain remote #53680
I have replaced the battery, however it is still not working. I've tried to find the instruction manual via Sears site but could not to check to see if I put the battery in the correct way, if I need to reprogram it or just what's up!
SOURCE: Sears Craftsman 1/2 HP Chain Door Opener
i had a problem with my craftsman 1/2 horse g.d.o.not being able to go down .it wouldnt reverse and close the door.after the second day of messing with it checking all the normal problems like the lite sensors and door binding and checking and setting the limit switches i was about to give up when i noticed that when i pressed the transmitter button to activate it to go down, there was a clicking in a selonoid that was attached to the printed circuit board.i looked it over again and again but i didnt see the problem when i deceided to use the ol "hit it with something trick" lol.well that didnt work either but what did work was to just use a insulated screwdriver and working from the circuit board side i gently pried the selenoid ever so slightely and it sparked and viola,the door went down.i guess what had happened was the selonoid had grounded itself out and it is what controls the "reversing" of the motor.this 13 years old and it now works great, set your limit switches ,check for any door binding and look over the printed circuit board very closely.listen for any clicking and investigate.
Posted on Oct 10, 2008
SOURCE: Sears garage door opener, chain adjustment
Loosen the inner nut on the trolley. (That is the lock nut). Then tighten the outer nut on the trolley to increase tension. The outer nut on the trolley is closest to the garage door. The chain tension should be 1/2 inch off the rail at midspan. (The chain is fastened to a threaded bolt on to the trolley. The threaded bolt has an inner and outer nut). Hope this helps.
Posted on Dec 24, 2008
  • 31 Answers
SOURCE: Sears Model 139.53985D - remotes suddenly do not
Make sure the batteries are good in your remotes. Next it might be your openers logic board. Get the numbers off the unit and look for a replacement on ebay as there are plenty of used good parts out there, heck even new ones if you want to spend the extra cash.
Posted on May 16, 2009
  • 3197 Answers
SOURCE: need a manual for sears model 139.18856, 1/2
According to Sears your model number is bad. Double check the number and they will have the owners manual with complete installation instructions.
Posted on Sep 25, 2009
  • 3197 Answers
SOURCE: Model 139.53930DM Remotes very eratic, will not
I am going to assume you have short range with your remotes and give you some stuff to check.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Posted on Nov 20, 2009
SOURCE: My Sears Craftsman Model 139 53684 Keyless remote
Make sure that when inserting the 9 volt battery that those red & black wires are not somehow pinched, twisted or stretched. I just fixed mine... The battery terminal was crushing one of the wires and preventing the battery to supply power to the keypad. I found it out by NOT securing the battery case door and my opener worked fine. Securing the battery case door with the screw and thightening, my opener DID NOT WORK. It was that simploe of a FIX!
Posted on Jul 06, 2010
0 characters
1 Points
My remote for my garage door quit working. Part #139.18791, can part #139.53681 replace it?
You may have to reconnect it to the garage door if you replaced the battery. There should be a "learn" button on the opener (usually a red square button (might be round). Read the manual but, in general, you push this button for only one second then go to your remote button and press that for several seconds. Again, the specific instructions may be different for your specific model year - they change from time to time. Check your owners manual for linking instructions.
Mar 09, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Keymaster Remote Pad does not reprogram The instructions say to type in my code, hold down zero, then press ENTER. The opener lights are supposed to flash but they don't. I've tried proceeding to enter...
Try it this way.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
We can only get one remote to work when we reprogram the next one the first one stops working. the key pad is doing the same thing
You are probably not reprogramming the remote or keypad, but are using the remote to reprogram the receiver. But I can't get the instructions from the Chamberlain site without a model number. Here is their site:
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
No instructions for reprogramming keyless remote
the chamberlain company is very nice go to sears and get number of side of box... sorry I cant remember off top of my head...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door not opening
First, check the safety eyes. There should be a light on on each eye. If not realign until they come on. On the wall button if the green light is blinking press the lock button on the wall control for three seconds. The light will go solid. If either of these do not fix respond with more detail and I will help.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
514 people viewed this question
Top Sears Garage Doors Experts
Al Clark
Pieter Vleeshouwers
Are you a Sears Garage Door Expert? Answer questions, earn points and help others
