SOURCE: My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
SOURCE: att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
SOURCE: Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
SOURCE: i need the remote code for a samsung series 7 lcd
How do i unlock the remote control of a Samsung LCD 46' series 7?
Faye
