Question about Sony Cyber-shot DSC-W100 Digital Camera
Reflectin Time and Date on photo's
Hi, Could someone tell me how to change the setting on the camera so that when you save your photo's to a hard drive it reflects the time and date on the actual photo.
  • 1 more comment
  • Anonymous Jan 26, 2008
    Same problem. How do you get date and time on photos to appear?
    How do you get date and time to show up on pictures.
    How do you get date and time on pictures.
How do I work thw hidden or reserve of pohhoootos
Posted on Jan 26, 2008
How do you change a date and time on a photo showing the wrong date and time my camera is fuji finepix F10
If you're referring to the date stamp on the photo itself then yes but not easily. You'd have to edit the photo the same way as if changing someone's shirt from red to blue or putting different lettering on a road sign in the background.
Jul 18, 2014 | Fuji FinePix Cameras
Problem with sony cybershot camera showing incorrect date- how do i change the date?
If you know how much wrong the clock was set, ie.
The clock was 1999-01-01 14:37 but it should have been 2017-05-22 19:00, there are softwares that could correct this error for a directory of files.
just search for exif time offset correct software (exif is the files hidden information about the photo)
Nov 16, 2017 | Sony Computers & Internet
How do I change the date and time on a vivcam8225
Hello and welcome to FixYa!
This following steps allows you to set the system time which will be displayed on the photos.
  • Press the Up or Down buttons to select the Date option in the Setup menu.
  • Press the OK MENU button.
  • Press the Up or Down buttons to select a Date option from the menu that appears
On selecting "On" the date will appear on the photo once it is taken.
On selecting "Off" no date will appear on the photo.
On selecting "Set Date" the Set Date settings screen will appear. You will be able to change the date settings that will appear on the photo once it is taken.
To Set the date:
  • Press the Up or Down button to enter the Set Date option.
  • Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
  • Press the Up or Down button to set the Date and Time digits.
  • Select the first option of the Date format and press the Up or Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
  • Press the OK MENU button to confirm, save the changes and exit.
You have done it.
I hope this solution helps you
If you have any more query or issue regarding your problem do inform me.
Thank you for using FixYa!
May 16, 2011 | Vivitar Vivicam 8225 Digital Camera
Model Sony Cybershot DSC-HX5...I need to have a time stamp on my pictures and was wondering if you can help me turn it on. Thank You
The new models do not have the feature of superimposing directly as many customers did not want this feature because accidentally they had this option On and the Date and Time stamp got printed on the photos even they didn't want it.
However, the new cameras that are equipped with the EXIF technology gives you an option to superimpose the date and time later by using compatible third party EXIF software.
You can also connect the camera to a Pictbridge compatible Printer to print the images with Date and Time.
By using the supplied PMB Software, you can print or save images with date when saving it into the Computer. Click on the below links for further information on inserting the dates using PMB:
Inserting the date in a photo.
Changing the date and time in a batch.
The customers can use the MS Paint to insert the Date & Time.
Thanks for using FixYa.
Feb 28, 2011 | Sony Cyber-Shot DSCHX5 Digital Camera
Don't display date and time
The date and time are always saved as part of the image file. You can turn off the date display on the image in the Menu system. Select the shooting menu (icon of a camera silhouette) and look for the Date Stamp option, change it to "Off".
Nov 16, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
Vivicam ..time and date
There will be a setting where you tell it to add the time and date by choosing ON. This is different to where you set the time and date. Generally it is within your menu and may be with ""setup menu"" and called "date stamp". If you set this to "on" it should do the trick.
Jun 13, 2009 | Vivitar ViviCam 3765 Digital Camera
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u!!!!
May 26, 2009 | Canon IXUS i7 Digital Camera
Setting up camera date
Took battery out overnight.
Nov 14, 2008 | Fuji Photography
Hi can you please tell me something in relation to my camera. I have a Panasonic DMC LX2 digital camera and I would like to know how to set the date to be used whilst I'm taking photo's, so when I go to...
The clock-setting instructions are on page 20 of the manual.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jul 25, 2008 | Kodak Easyshare M753 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
102 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
