Question about Whirlpool LGQ9858P Gas Dryer
MY WHIRLPOOL DRYER
THE DRYER WORKS, BUT NO HEAT COMING OUT OF IT. I DONT SEE A SWITCH IN THE BACK FOR RESET. WHAT SHOULD I DO?
  • CALIARCH Jan 25, 2008
    MY MODEL # IS LGR7646EZ2
  • dzweng Feb 27, 2008
    Whirlpool LGR7646EQ1 Gas Dryer. No heat coming out of it even though it works every cycle.
    Master:
  • 619 Answers
Hi , mostly broke or busted are the heat sensor if that will open no hot produce .
Posted on Jan 25, 2008
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
Dryer not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 29, 2011 | Whirlpool LEB6200 Electric Dryer
Whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Jun 14, 2009 | Whirlpool Dryers
My dryer was working fine last night, then today, no heat. The vent is cleaned, nothing in there...heating element?
Heating element maybe not likely.
Probably thermal switch overheat protection tripped.
Try putting in lower heat mode (touch up or permanent press) see if you get heat.
Some thermal switches can be reset most have to be replaced. $20.00 to $45.00 Plus labor $??.?? to $???.??
Hope this helped. need more help MSG Back. Please rate. Good Luck!
Mar 12, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer heat not working
DO YOU HAVE A METER? FIRST CHECK THE DOOR SWITCH,SECOND REMOVE THE BACK PANEL AND CHECK ALL FUSES AND THE HEATING ELEMENT,LET ME KNOW WHAT YOU FIND AND WE CAN GO FROM THERE-MIKE
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not heating, Interimittent Problem -------------------------------------------------------------------------------- Having an intermittent problem. The dryer turns on, drum spins, but you have no...
Have you tried to bypass the hi limit switch or the thermal switch. It will work. If it works for a few times, then you will know the switch is bad. I did this on a friend's one time and it solved it. Only cost about 15 bucks. Godd luck and let me know how it turns out.
Jan 13, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not heating
it could be your limit switches or your heating element gone bacd if you dont have heat. those are the only 2 options
Dec 28, 2008 | Whirlpool LER4600 Electric Dryer
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LGQ9858P Gas Dryer Logo
311 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
