Proscan service number or service center in so cal
My proscan flat tv won't turn on. Red light is on, green light onm power supply on. It appearts I need a power cord. I need the service phone number as this is still under warrenty. Does anyone have the contact service phone number or a local warrenty shop in orange county, california?
  • jjuriga Jun 25, 2008
    SAME issue! Anyone out there help? I cannot get Proscan to call me back!
SOURCE: Sova Digital DS205-S32 Television power cord adaptor
Here is the contact info I found for SOVA. Hope it helps... Registrant: Sova Digital Inc. 17300 Dallas Pkwy Suite 3158 Dallas, Texas 75248 United States Registered through: GoDaddy.com, Inc. (http://www.godaddy.com) Domain Name: SOVAUSA.COM Created on: 12-Feb-04 Expires on: 12-Feb-07 Last Updated on: 22-Feb-06 Administrative Contact: , yongshen@sovadigital.com Sova Digital Inc. 17300 Dallas Pkwy Suite 3158 Dallas, Texas 75248 United States Technical Contact: , yongshen@sovadigital.com Sova Digital Inc. 17300 Dallas Pkwy Suite 3158 Dallas, Texas 75248 United States +1 (972)8181088 Good luck.
Posted on Jan 10, 2007
  • 362 Answers
SOURCE: alarm led on samsung pcb model #lj44-00025a
Hi ralopez satx,
I have provided a link to the service manual, with a multimeter you should be able to track down the problem. Let me know if I can help and please rate this solution. Lone99star in Texas also
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 22, 2009
  • 32 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
dsacco86
  • 1077 Answers
SOURCE: won't turn on
I want to save you time and money here.
A new TV just like the one you have at Walmart cost $189.
A TV repair shop will most likely charge you $100 just to look at it. And the part, Backlight Inverter/Power Supply Board ( I believe that is broken ) will cost $110 min ( That's a used part).
It would definitely cost more than $210 to repair the broken TV vs buying a replacement 19" TV at Walmart for $189.
Posted on May 26, 2009
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
Proscan 42LA45H 42 in. LCD TV won't turn on, no red led when plugged
The power supply is the most likliest cause of the issue. You can get replacement power supply from www.tvcircuitboards.com
Mar 02, 2012 | Proscan 42LA45H 42 in. LCD TV
When I turn the tv on it show a blue light but now the tv won't turn on and a red light keeps blinking. What should I do?
Replace the defective electrolytic caps on the power supply and/or replace power supply, check at www.partstore.com That should fix your problem.
May 31, 2011 | Proscan 32LA30Q Television
Proscan model 19LA20QW Turn on TV the light turns to green for a second then go's to red flashing
i had the same problem. i replaced the power supply and the tv worked great after that.
Sep 27, 2009 | Proscan 19LA25Q 19 in. LCD Television
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Proscan 19la25q 19in lcd
Is there a red L-E-D power light beneath the screen? that is the power off light(red). Watch closely to see if that red light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply. There are replacement power supplies on ebay. Be sure that the positive (+) is the center hole of the plug. Most likely all of them are. The output plug is 5.5mm x 2.5mm in size.
Mar 08, 2009 | Proscan 19LA25Q 19 in. LCD Television
I cant get the tv to come on it has power
You have a bad power supply (AC adapter). Watch closely at the red light while turning tv on to see if red light momentarily flashes green, then back to red.
Dec 15, 2008 | Proscan 19LA25Q 19 in. LCD Television
Help fix screen t.v.
What red light are you referring to? If you are talking about the red l-e-d power light beneath the screen, that is the power off light. If that red light light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply.
Oct 22, 2008 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
322 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
