Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Need to replace the helix cap on amana ice maker
The helix cap is worn so the auger slips out of place and jams on the side of the ice bucket. How do i get the old cap off and the new one on
  • 1 more comment
  • lakemigal Dec 07, 2008
    My Amana refrig, will make but won't dispense ice. The auger motor turns but the auger doesn't look correctly attached to the helix end cap that connects to the motor. .
    Do you have a picture of what the cap and auger should look like when correctly attached together? I'm confused about how much of the auger should be inside the cap (through one of the slot holes) as about half of a spiral rotation is inside now and that makes the cap off center so the auger won't spin.
  • brajean May 11, 2010
    need a spec sheet to replace auger
  • robert samples May 11, 2010
    whats the model off the amana
dididsaythat
  • 291 Answers
SOURCE: ice maker water will not stop/overflows
either u got a bad ice maker or the spout going into the ice maker is leaking, ect.
Posted on Sep 03, 2007
fanny
  • 146 Answers
SOURCE: ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it.
2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
Posted on Oct 30, 2007
MNfisherman
  • 11896 Answers
SOURCE: The ice maker works, but does not dispense
The bar, hinges or sensor may be broke or shot..
Posted on Jul 08, 2009
  • 415 Answers
SOURCE: Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Posted on Aug 20, 2009
milten1
  • 1304 Answers
SOURCE: Kenmore Model 106.54619300
not knowing your ice maker model
if you have a white box like cove on the end,
pop that off
you will be looking at the ejection moter wheel
to the botom right, you should see two holes
one T one H jumps those out with a small peice of wire, you may need to hold the door switch on the freezer,,,,
if you jumped it out correctly, yo will hear a definitive click,
take out the jumper
watch the whole cycle 3=mins
keeping an eye on the ice machine the whole time
if it does everything but eject your motor is stipped
and you will need a new one
Posted on Oct 06, 2009
Our ice maker has rust on ice sometimes and can't understand why or how to fix
You would need to remove the ice storage bucket and dump the ice, check the corkscrew wire in the bucket for any signs of rust, some auger wires were chrome plated and not aluminum. If no rust there, remove the ice maker it's self and check the ice making mold for signs of rust. Replace all rusted parts found. Pleazer Appliance...
May 06, 2014 | Frigidaire GLRS237ZA Side by Side...
Maytag H2O MFI2568AES Ice Maker keeps jamming
Most ice and water units have heater elements inside the door and in the ice chute itself to prevent water and ice from freezing in those areas. Its possible that one of the heater elements has failed. You will need a wiring diagram and a meter to test if the element is OK or not.
Feb 22, 2014 | Refrigerators
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
Amana side x side ARS2464B circa 2000. ice maker issue - during ice dispensing mode the auger will occasionally bind up and ultimately pop the auger off track from the rear driving side and i have to keep...
I am having the exact same issue -- how did you get the auger to slip back inside the drive gear? I've been trying & trying, and my hand hurts yet no progress. Thanks.
Jan 05, 2011 | Amana ARS2464B Side by Side Refrigerator
Ice dispenser
THere is a plastic "hub" at the back of the bucket which attaches to the auger. THE "hub" catches a "fork" like device at back of ice maker which turns. The "fork" turns and in turn is supposed to turn the auger. That plastic hub could be torn up, broken, jammed, or otherwise not working correctly. That is what is wrong with mine.
Jul 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore model 106.57022601 side by side. Ice maker works but the when the lever on the door is pressed nothing is comming out. My husband could fix it if we could find a manual. Does anyone have any...
Check the button that the lever pushes when calling for ice. Also check voltage to the auger motor. If your ice bucket is in the door then your auger motor is under it...also in the door. There is a little cover under one of the freezer door shelves that you have to take off. 3 or 4 screws hold it on. Right in there you will see the auger motor
Sep 11, 2009 | Amana ACD2232HR Side by Side Refrigerator
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Dispenser not working on PSS26SGPA Stainless Side by Side
This is a common problem with this GE and "lookalike" models. The dispensers first break the front plastic drum that holds to the auger and eventually cracks the rear circular sleeve as well. Pieces from the drum usually fall off and are even dispensed with ice ... eventually the drum is damaged enough that the auger no longer operates. The motors on these units, however, continue to operate.
You can receive the replacement parts needed to make the ice maker auger operate again by visiting the GE parts website. A usual repair will run $40-60. Unfortunately, the design of the replacement drum has not changed, so be prepared for this to happen again.
Best of Luck.
Apr 24, 2007 | GE Profile PSW26P Stainless Steel Side by...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
141 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
