Question about RCA HD52W56 52" Rear Projection HDTV
Closed caption im tryin to get closed caption on my rca by doing it manually but it still doesnt work?
  • Deborah J Jan 28, 2008
    Thanks gameboyfreak but I dont have the remote.....that might be the problem. I have tried to do it manually but it doesnt work help me again if you can....
  • Deborah J Jan 31, 2008
    thanks again gameboy i have tried that and for some reason it just doenst come up. i have gone in manually thru the set up menu and did everything you said. but for some reason it still doesnt work.i have it on cc1 always on but it still doenst show words.i have even had the person that is hard of hearin try it and he couldnt figure it out either. HELP
    Problem Solver:
  • 17 Answers
Have you verified that the programs you're viewing have closed-captioning service? Some programs and stations do not support CC on programs and commercials. The closed captions are accessed on the HD52W56 by pressing Menu > Preferences > Closed Captions on the remote control and following the onscreen instructions. Select CC1(the first choice for caption); this is the format most stations send in. Good luck!
Posted on Jan 27, 2008
  • Anonymous Jan 28, 2008
    I think you can press the 'Menu' button on the front panel of the set and then use the Channel buttons to move up and down and the Volume buttons to move left and right. Use Volume Up to move into a menu and Volume Down to exit a menu. If you need, I can type up the specific button order to reach the caption menu.
6ya staff
SOURCE:
Need Closed Captioning
If you have the original remote control, there will be a button marked "CC", and pressing it once, the closed caption funciton will turn OFF, and for an other press, it will re-appear. Now, here you are using a universal remote control. So it will be difficult to make closed caption. Try to enter its function menu by using present remote control, where you can make this funicion OFF, if you could enter into it.
Jun 02, 2013 | Insignia NS-RTV32 32" TV
How do I turn off closed caption on a RCA GUIDE PLUS GOLD GEMSTAR?
Press the "CC" button on the remote controll once. If there is no such button on the remote control, get into Menu of the TV, surf thorugh, come to closed caption optione seclect fucntion, and make Closed Caption to OFF.
Apr 09, 2012 | RCA Televison & Video
Closed captions stopped working
Is this on everything you watch? Not all shows or broadcasts have closed caption.
Does it work when you mute volume? Closed caption can be set to only come up when volume is muted. If so, check settings in menus.
Apr 06, 2009 | RCA Televison & Video
Closed caption on. Want it off.
the closed captioned in stuck in spanish on the screen does not move how do we remove this.
Jan 21, 2009 | RCA RCU4GLW Remote Control
Can't get the closed caption on
Press Menu on Front of TV Go to Setup then go to closed caption turn on. you can do this on Front of your TV using CH- CH+ will allow you to go up & Down Menu and Vol- Vol+ to Adjust.
Dec 25, 2008 | RCA R52WH73 Projection Television
Turning off Closed Captioning
On the 27" TruFlat the closed caption button is hidden within the DVD buttons. You have to press it multiple times to shut off closed caption. It seems to have multiple sources for closed captions. Press the button until no source appears on the screen. ITS CONTROLED AT THE REMOTE CONTROL - NOT ON THE ON-SCREEN TV MENUS. Good Luck
Nov 27, 2008 | RCA TruFlat 27F520T 27" TV
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Rca system link 8av remote How do I turn off closed caption??
CC is usually turned off by selecting an inactive choice,i.e.
If CC1 is on, then try CC2......
Further info ? Please provide Model # of TV.......................T.
Dec 31, 2007 | RCA Universal Remote Control
Closed captioning
use the one on yoursky remote it has its own subtitles.
Nov 07, 2007 | Durabrand DU1901 TV
RCA HD52W56 52" Rear Projection HDTV Logo
119 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
