NAD C320 2-Channel Amplifier Logo
Posted on Dec 23, 2009
NAD C320 BEE - goes silent. Only yellow light.
NAD C320 BEE - so I'm listening to it in AUX mode, have it connected to my laptop to listen to i'tunes. Suddenly it went silent. The light is yellow and you can't select any input :( No music at all
Fuse? Am I going to have to pay big bucks to get it fixed?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
748
Points
Just came accross your post accidentically, while reparing my own C320BEE. May be it 's too late for you now, but it could help others: I had the very same symptoms as you described and after a long search found out that the trouble was R45 in one of the 18V regulators. (R45: 33 ohms 1/2W fuse resistor, situated more or less half-way between the two "metal towers" on the main board. Replace by a somewhat stronger type 1W or so.
Likewise R46.)
Anonymous
Level 1:
New Friend:
  • Posted on Aug 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
748
Points
Just saw your post and it looks like I have a similar issue with R45, tried replacing it with a normal resistor but that fried too. In the process of checking the whole circuit now. keep you posted
  • starcrouz
    starcrouz Jan 15, 2014
    Same for me. R45 is fragile.
1helpful
How to connect an MP3 Player to NAD C320?
You will need a cable with headphone jack (for mp3) and RCA left/right to connect to your NAD 320. You can connect to CD or AUX in the back and then you will need to change the input with remote or with on board buttons to CD or AUX depending where you plugged it.
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
Hi please help i cant find the specs for the C320
Not much - I saw one quote at 40, one at 50 watts rms. Strange that the manual doesn't include specs.
http://www.amazon.co.uk/Nad-C320-BEE-titane-Amplifier/dp/B0001HYIMS
2answers
C320 MERCEDES STEERING NOISE
This could be a serious problem. Listen real closely the next time your car is started. Is the noise coming from the steering column or the ACTUAL Dash area. Listen closely to see if it is coming from the area where the key is pushed into the ignition. If so!! This could get real bad quickly. There is a unit in there that controls almost everything with the key in the (ON) Position. CHECK AND LISTEN! Also if its not anything like this it could be your (Air Conditioning flaps) They open when the car is turned on to the last known position and something could be stuck in there!
How do I setup the SoundMAX device for AUX line-out?
The cable from the computer simply needs to be plugged in to the speaker/headphone jack on the computer, then run to the AUX input on the amp. Make sure the volume on the computer is set to about 75% - 90%.
AUX problem between my laptop and NAD C 320BEE
HI...
I would check on the Soundmax software set-up on the PC and make sure that the AUX is set for a line-out connect.
Also,make sure the tape monitor isnt on ..On the amp
2answers
Nad 310 amplifier VERY QUIET
take audio out from tv and insert it in aux in in your amp.
NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
