Question about Denon AVR-1802 Receiver
Denon AVR-1802 Have had this receiver for 8 years with no problem until now. Today the volume keeps spontaneously increasing. First a little, then gradually gets really loud. I can see the volume numbers on the receiver changing. Ever hear of this problem? Is it fixable?
  • dougdenon Nov 28, 2008
    I have a very similar problem with my 7 year old Denon AVR-1802. The receiver will spontaneously go to full max volume (+18 on the front panel) in about 1 second. I have no solution.
    Genius:
  • 1,067 Answers
Might hav eto buy new control modual parts store hi end parts store order one for u
Posted on Jan 25, 2008
  • nick helpap
    nick helpap Jan 25, 2008
    maby ebay or denon direct
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
I am trying to use my Denon AVR-1802 to connect my cable box to my TV. The problem is that I don't have any speakers connected to the 1802, I just want to route the cable box's video and audio to the TV...
connect your analog output from the cablebox to the receiver md/tape in. then connect your tv audio input to the md/tape out of the receiver. or you could just pass it straight from the box to the tv, bypassing the receiver altogether.
Nov 03, 2009 | Denon AVR-1802 Receiver
Denon avr 1802 died after lightning strike
I hate to be the bearer f bad news but it has been my experience , anything hit by lightening stays hit permanantly ..
You may find a few components on the quick scan of the circuit burnt or damaged , but you can guarantee that other components have been fried also .. It does enough damage to any electrical system when you get a 300v spike on the mains .. so imagine what approx 1/2 a million volts will do to a 12 volt radio ?? dont waste your money call your insuarnce company and claim for it ?. ... Regards vortash
May 02, 2009 | Denon AVR-1802 Receiver
My Denon AVR-1802 is permanently stuck in tone defeat. The display actually shows that the tone defeat can be turned off and on, but the tone controls, ie. bass and treble do not alter the sound in any...
Is this only when using external inputs? The manual says the Tone Control will not function in Direct Mode. Try Stereo and various DSP surround modes to see if the Tone Control works.
Apr 21, 2009 | Denon AVR-1802 Receiver
Denon AVR-1802
Providing we are talking a standard tall pin Ic ie not a flat surface mounted variety you shouldnt have too much trouble with the soldering as long as you have a steady hand .. remember not to leave the iron on the joint too long or the print will lift and keep the tip clean to aid heat flow to the solder .. here are a couple of web adresses that might help you get the components you require and good luck oh by the way dont forget static precautions , touching an Ic alone without gorunding yourself first with a static strap can blow some sensative ic's http://www.rscomponents.com and http://www.maplins.com also http://www.radioshack.com
hope this helps and again good luck . .... Reagards ..Vortash
Jan 17, 2009 | Denon AVR-1802 Receiver
Digital audio cuts out.
I have same DD 5.1 tiny "bursts" problem with satellite HD channel. It is probably problem with Crystal DSP (German site): http://forum.digitalfernsehen.de/forum/showthread.php?t=89328&page=3
"Denon bietet Lösung für EX-Flag-Problem bei den Modellen AVR-1602 und AVR-1802 an
07.08.2002(cr)
Dass die Denon AV-Receiver AVR-1802 und AVR-1602 die mit einem DD 5.1EX-Flag versehenen Tonspur von "Atlantis" und dem "Herrn der Ringe"nicht abspielen können, ist ein spezifisches Problem von einerbestimmten Revision des in diesen Geräten verbauten Crystal DSPs.Dieser Chip wird u.a auch in einigen Kenwood- und Onkyo-Modelleneingesetzt.Da es von diesem Crystal Chip unterschiedliche verbauteRevisionen gibt, von denen aber nur eine bestimmte betroffen ist,werden die beiden Filme auf dem größten Teil der verkauften AV-Receiverohne Schwierigkeiten laufen.
Denon bietet nun für alle betroffenen Kunden, die ihr Gerät beimdeutschen autorisierten Fachhandel erworben haben, eine kostenloseModifikation an. Das Gerät muss beim entsprechenden Fachhändlerabgegeben werden mit dem Hinweis auf das Herr-der-Ringe- bzw.Atlantis-Problem.
Momentan steht nur eine begrenzte Anzahl an DSPs zur Verfügung - Denonhofft, dass kurzfristig ein größeres Kontingent eintrifft.
Denon bittet daher die Kunden freundlich um Verständnis, dass nichtalle betroffenen Geräte auf einmal und sofort umgerüstet werden können."
May 23, 2008 | Denon AVR-1802 Receiver
Remote control for this model AVR 1802 is failed to work , i want spare
Many original remotes are exspensive and hard to get hold of , Radio Shack or Maplins have many universal remotes that not only will allow you to control your AVR 1802 but many other devices you have also ... at probably half the price . ... regards Vortash
Apr 17, 2008 | Denon AVR-1802 Receiver
WIRELESS SPEAKERS
There are many kits at Maplins or Radio Shack that will do this for you , you can search for them at http://www.maplins.com or http://www.radioshack.com you may even be able to build one yourself from circuits available off the web .
Yes you will be able to use your own speakers and your options are basicaly down to what you can afford .... Regards Vortash
Jan 11, 2008 | Denon AVR-1802 Receiver
Denon UD-M50 amp/3 cd changer
The tact switch behind the panel is being pushed in by a defective front panel button, the small switch is bad behind the button, or the volume control IC is bad. Good Luck
Aug 11, 2007 | Denon DCM-35 CD Player
Denon AVR-1802 Receiver Logo
204 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
