Question about ViewSonic PJ551 Multimedia Projector
Source of laptop
I just bought this projector. I cannot get the cd to play on my windows xp based computer. I cannot get the source to see the laptop power point.
    Problem Solver:
  • 5 Answers
Sometimes it helps to hook up laptop and then power everything up at once. Also check and make sure that you have the source looking for the laptop or have it on auto search for it may also need to the check the menu for the projector to see if the may have a manuel connect for the laptop to be able to view
Posted on Jan 25, 2008
6ya staff
SOURCE:
Compaq 3800 projector.I have a Carbon X1 Thinkpad . I bought 3 different cables already,it can not find the source.Fn-F4 nothing-Lower resolution nothing.If somebody has an answer please shoot
wow what a complex post.
why not tell a story, use notepad, and type it and paste it here so we can see whats UP?
what are you attempting, seems the Projector is dead, right>
what cable, did you use a short direct VGA cable.
is it VGA> seems yes, you said, Fn-F4 so is VGA
my guess is its custom long cable you made bought or?
what does this line mean.???
With my Desktop is not problem!
i can not understand any of this , and ive run projectors 100s even 1000s of feet, in airports and other huge , venues.
my guess is you do not understand video and its limits.
you can not send high resolution to a old projector
and windows 10 does not run low reso. unless force
windows 10 does not run old obsolete displaces or chips at all.
now.. they are obsolete... i can list 1000s dead now... can.
The DLP projector is a very cool thing,Texas Instruments based magic.
but is old and has 1024 x 768 native resolution
so to get that to work with XP,.W7, W8 or W10
the latter is most hard, as W10 does not work and low reso.
(means not automatically work)
you have to force it.
(btw, in say xp/w7 go to safe mode F8 and force low reso.)
to do that SAY< in w10, you'd rigth click your desktop screen
go to settings then advanced display settings
click screen pick display setting, at bottom of that screen pick advance settings.
then pick above reso.
i just did and screen goes SQUARE 4:5 mode.
ugly by todays standards.
not plug in the projector and press Fn +F4 bingo, out it goes.
keep in mind some GPU chips many not allow this.
id need to know each chip in each machine used to answer that.
if the projector fails now, then try a regulor desktop monintor now
at the PC under test VGA port does it doe above reso.
yes then the projector has issues.
all this done with short 3'ft standard VGA cable as see on back of
all VGA monitors use that to test and get that work ing before using wild custom cables, unstated by you...
but youve posted before on this setup, have you not.
Feb 24, 2017 | Compaq Computers & Internet
Cannot find the source
Try lowering your laptop's screen resolution and refresh rates to the lowest possible.
Additionally, you need to press Fn + F? keys on the laptop to cycle on laptop display, laptop display + external; display, external display.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Optoma HD70 DLP Projector
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
The projector can't find the source, which is my laptop. If it does find it, it lasts one, maybe two seconds, and then it's lost it. We've tried two different laptops, and it cannot hold the connection for...
Maybe the cable connected to the projector is bad?
If you shut down the laptop and plug the projector in on 'PC' mode, does the projector recognise the video output?
Jun 09, 2009 | Dell 2400MP DLP Projector
Delay/ whitescreen when projecting video from laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
Jan 08, 2009 | Dell 3300MP Multimedia Projector
How do I start fresh with my used Compaq Presario 2538CL?
stick in windows xp cd got keys i hope then boot to it from bios set cd player to boot 1st in that order then when u boot up ask u boot from cd from ther follow on screen ins ok easy then update it ect get latest drivers in do windows custum scan
Oct 06, 2008 | Compaq Presario 2538CL Notebook
Won't project; can't find signal
Make sure that your computer was turned on first (don't ask me why). Then hold down the Fn key while pressing F8. Hope that helps.
Aug 28, 2008 | Dell 3200MP Multimedia Projector
Video out
try to reconnect your cable of your projector just make sure that well-fitted on the port and screws are intact then to try to restart your laptop.ok?
if still doesn't work.just let me know!!
Jan 16, 2008 | Dell Latitude D600 Notebook
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
ViewSonic PJ551 Multimedia Projector Logo
111 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Joaquim Martins
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
