Question about Maytag SkyBox MBV1976A Beverage Dispenser
Low product light stays on
One rack of my skybox has the low product light on even though the rack is full. I've tried power cycling, etc. but the light stays on no matter what. This just happened fo seemingly no reason.
    Problem Solver:
  • 6 Answers
You can go to partselect.com and purchase a new switch for the low product. It mounts on the back of the dispensing rack, item number is 18 on the assembly diagram. It is also possible that the existing switch has become unplugged from the board by ice buildup.
Posted on Jan 25, 2008
6ya staff
SOURCE:
Low coolant level light on
Check that the wiring and terminals to the sender unit are not broken or dirty. If they are good maybe the sender unit it self is not working.
Jun 07, 2015 | 1985 Jaguar XJ6
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Electrolux icon duel fuel range racks red light wont stop flashing even though I removed all racks, so oven will not start self clean cycle
Good Morning Andrea,
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Mar 23, 2014 | Electrolux Icon E30df74gps 30" Pro-style...
Low washer fluid light stays on
Either the resivoir is low of fluid or the sensor is stuck down or defective. Inspect the fluid level sensor.
Jan 03, 2011 | 2005 Chevrolet Malibu
1999 Olds Alero. Low coolant light comes on and stays on even though its full. Starts running hot to the 3/4 mark. When the heater is turned on it cools off. Could this be the thermostat or the water pump.
TAKE RADIATOR CAP OFF WITH ENGINE COLD AND CHECK WATER ..MAKE SURE RADIATOR NOT BLOCKED,,PLASTIC BAG ETC. THIS SOUNDS LIKE LOW WATER OR RADIATOR ..STOPPED UP INSIDE ..IF YOU HAVE GOOD HEAT IT'S FULL OF WATER. REPLACE T STAT B4 RADIATOR..IT'S CHEAPER. ALSO CHECK FOR RADIATOR COOLING FAN OPPERATION..I,M RULING OUT THE WATER PUMP.
Mar 20, 2010 | 1999 Oldsmobile Alero
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Maytag skybox not dispensing
sounds like the ribbon cable that connects the mechanism set to the rear control board has become unplugged. I have a troubleshooting guide. email me at [email protected].
Apr 01, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
jasbo
jasbo
Gil Shultz
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
