Question about Saeco Royal Professional Espresso Machine
New Royal espresso machine
Using water tank, first time getting Ventilate message
  • 1 more comment
  • Anonymous Aug 01, 2008
    ventilate message on machine, what steps do you take to ventilate?
  • iamwhatiam Aug 28, 2008
    I read the many responses and suggestions. The mess
    age I got after turning the Saeco Royal Professional coffee machine Is "ventilate" after it started to warm up. I have removed the water container, and tried to see if it appears to be a any leakage of water. none. I turned the machine off again, and then tried to use the menu to see if the machine can be turned on another way. none. Then , I turned it off , and then back on (minutes later), this time the message "ventilate" appears and the menu button does n't even display anything......... I tried to read the manual, no luck as to do about anything. The only reference to "ventilate" refers to the water pump being broken. Of course, reading through the maize of foreign lanuages, it is extremely difficult to read anything in a straightforward manner. I absolutely don't and can't afford a major repair expense. I am really anxious to know what other measures I can take short of slpending hundreds of dollars in repairs and the cost of the boiler itself. Even if I send it for repairs------ I am certain the repair shop will insist it needs a new boiler, pump in all, even if doesn't need it----- and then I would never know . Anyone, PLEASE let me know if there is a way to determine what the situation is, and IF I can do something different?????????
    Iamwhatiam
  • snoof May 11, 2010
    Thanks jonnycole for your information,
    I have run the hot water nossle untill the airlock clears. I heard it splatter but still nothing, but new message appears to addition of ventilate message, it's says descale, and ventilate, plus no water comes from the hot water nossle any more only steam.
    It would be fantastic if you guys could help us on line, as we leave in the middle of the south pacific and it's quite complicated and expensive to send it overseas.
    Thanks you for your reply.
It means you have an airlock in the water system. It can occur when you refill the water tank also.
Quite often you can run the hot water nossle untill the airlock clears. You will hear it splatter and then it should be sweet to go.
Posted on Feb 14, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
What if it is plumbed in the back?
Posted on Sep 30, 2008
Machine says Ventilate ?
You have run Hot Water ?
You cannot get steam ?
Still says Ventilate ?
Take the filter out of the tank and try running Hot Water again
Works like a charm now
New filter and descaler on order :)
Posted on Sep 15, 2008
  • 2,039 Answers
Ventilate mean machine on water in machine ready open side vaive water gonna come out and that it ventilate will go off enjoy cheers
Posted on Jan 26, 2008
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: New Royal espresso machine
Run hot water cycle to ventilate machine.
Posted on Mar 09, 2009
My saeco royal has ventilate on the screen and is not working. what does this mean?
Hi That means the pump needs to be primed by running water through the wand. Push the water. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
Feb 08, 2010 | Saeco Royal Professional Espresso Machine
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
Constant ventilate message
mine says the same thing, run hot water from the hot water/steam nozzle until the message disappears. do this a few times, mine is working fine after doing that. hope this helps
May 09, 2009 | Saeco Royal Professional Espresso Machine
Mar 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Royal Professional machine
try to set the grinder to grind little more coarse, you have to make 2-3 cup to get the new settings to work.
To get off the ventilate you have to press the button for hot water and make a cup of water.
Hope this will help you.
/Mirran
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
Ventilate!
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website: http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit www.CeriniCoffee.com
May 29, 2008 | Saeco Royal Professional Espresso Machine
Ventilate
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
If this does not work, feel free to contact us on our website for more help.
For Saeco Parts or Cleaning supplies for your espresso machine visit www.CeriniCoffee.com
May 26, 2008 | Saeco Royal Professional Espresso Machine
Keep reading "ventilate" on the screen
Running hot water button a few times worked for us
Dec 18, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
995 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
