Question about Haier HTF24R21 24" TV
Exiting service mode (i think)
I turned on my tv this morning and it was in a strange mode were i couldnt do any of the normal functions eg. change chanel volume ect. The display show Service v2 up the top left corner with sts 0 : 01010010 ect ect below. My question is how do i exit this mode and also how did i get into it in the firstplace.
  • 25 Answers
If you have pp button on remote press it.or try with main sitch
Posted on Aug 26, 2009
I have a roshan TV,I tried to change the channel this morning and FACTORY came up on the screen n now I can't change the channel r do anything onthe tv...rs17-8895m
The TV is now in Factory Mode [Service mode] state. You should release it, to normal state, to get normal picture. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 14, 2016 | Televison & Video
Tv word factory screen remove
What is the brand name to your TV? Your TV is now in service mode [factory mode] now. That is why, it shows the display 'Factory' on screen. You have to quit the service mode. Then only you can enter into its normal menu. But, entering and exiting factory mode/service mode, to different brand TVs will not be the same. http://electronicshelponline.blogspot.com/ Check this link. It has service mode entry and exit methods to many brand TVs. Pull up older posts there, either by its left side bar, or, view it in 'Timeslide' option. Look for the service mode entry and exit method to your brand TV. You'll get details there.
Jun 19, 2013 | Sansui Televison & Video
Pt 53x54t reset to factory settings
To make it to factory settings, you have to enter its service mode option. Service mode window will be entirely different to that of normal window. Entering and exiting service mode to many brand televisions can be noted by this link. http://electronicshelponline.blogspot.com/ Pull up older posts there. Beware. Do not make any other adjustments there, other than factory reset. Changing data values, without knowing more about what will happen after that, is not recommended. It might even make the set inoperative to any more external commands, either by its front panel control or remote control, In fact, a dead waste set will be the result. Make sure to exit the service mode, after make a factory reset. For more details, check the link sited above. Read all instruction well before start.
May 31, 2013 | Panasonic Viera TH-42PX80U Plasma TV
My tv is changing channels it self
The memory IC to your TV is faulty. Check and replace it. This is an eight solder terminal IC, can be located very near to main system control IC. Even though physical size to this IC is so small, function to it in circuit, when the TV works is great. You must have thofough knowledge in electronics to do this work, because, you might have to enter its service mode option to do some adjustments. This work is very skilled one, as service mode option window, and normal user window are entirely different to each other. Adjusting wrong data value to service mode options might make the TV irreparable, and irresponsive.
Jul 04, 2012 | Televison & Video
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
Have a philips tv and a home theatre system but the remote off the surround system just changes the tv settings. Its kind of frustrating when I want to watch a dvd! Do I have to assign a freq?
When you press a function key on the remote control, not only does it change the function on the system (eg DISC, TUNER, TV etc) but it also changes the function on the remote.
However, if you change the function or source on the system, then only the system changes.
It sounds like you have changed the function on the system to DVD, but the remote is still set to TV. When in TV mode the remote will send Philips TV codes.
Press the DVD or DISC button on the remote.
May 10, 2008 | Televison & Video
All different brand of PTV has there way of excisting out of the service mode, panasonic don't list it, very hard to do, turn tv off then you see.
What about Bob
Mar 01, 2008 | Panasonic PT-47WX42 47" Rear Projection...
HTTP MESSAGE ON SCREEN
Go into your closed caption settings and most likely you have accidently activated one of the TEXT modes. Turn that off and your TV should be back to normal.
Feb 14, 2007 | Sharp Aquos LC-15B1U 15 in. LCD Television
Haier HTF24R21 24" TV Logo
132 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
