Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Kenmore frige model 59658692890 evap fan will not start
Tested temp control. It checked out good.,
Defrost timer operates compressor/condensor, but evap fan will not run.
Evap fan ids good. Tested by applying 120 volts directly to contacts.
Also, what is trhe ammana model number cross-reference for this frige
  • crobarent1 Jan 25, 2008
    Unit is not stuck in defrost. In fact evap coil is freezing over. I can manually switch fro run mode to defrost mode by utilizing knob on timer. Again, the defrost timer operates all componets properly, but fan will not start.
    Problem Solver:
  • 10 Answers
It won't run if unit is stuck in defrost.
Posted on Jan 25, 2008
6ya staff
SOURCE:
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
I have a magic chef refrigerator model # mcbr415sf. The top freezer part does not get cold enough to keep ice cream cold, but when you turn the temp up -- there is only one temp control and that controls...
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
You can fix this by yourself and do take care in solving the problem......
May 12, 2011 | Refrigerators
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
No cooling or compressor operation
Compressor and evap fan cycling are controlled by a circuit board as well as the defrost. It is all in serie - once your defrost kicks in contact is cut from the evap fan and compressor - once defrost is finished the switch reverts back to normal operation and your evap fan & compressor turns on.
Most common causes of this issue is either a defrost timer fault or control board (burnt resistor or bad board).
Inspecting and changing the control board will usually fix the issue - if your evap fan comes on after changing the board but not the compressor then you have a bad compressor.
If you have one of those units like some whirlpool/Kenmore/Inglis that have electronic controls in the refrigerator section, this is the board that controls the thermostat and compressor on/off cycling. The board behind your freezer is also connected to the board in your fridge, this one controls the defrost.
Sep 27, 2009 | Amana Refrigerators
Frige not cooling, freezer is fine
its the problem of defrost timer.due to this the cold air from freezer section is not getting in to refrigerator section and its getting warm.check out the defrost timer.located beside the compressor at the back lower side of the unit.the cost of new defrost timer is near to $40.and you can get it from
www.repairclinic.com
thanks.
Jul 14, 2009 | Jenn-Air JFC2089HE French Door...
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
GE PSC23NSD SS refrigerator malfunction
Check the cover in back of the freezer for for frost build-up. I think Frost reached the evap fan-blades and stopped it from blowing cold to the ref-side. Contro;s can be confusing. The ON-OFF controls how long the compressor runs, and the other dial how open or choked the airflow from the freezer into the refrigerator. Sometimes it happens that you have that flapper shut and no air is getting moved to the reefer. If frost is on the cover you have dead heater elements on the evap coils or a faulty hi-temp limit switch, which is the disc thingee at the top of the coils. A bad timer also may disallow it going into defrost - think about it. Chris in big bEar
Apr 20, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Frigidaire FRS23H5AS side by side. condensor fan runs, no voltage to compressor
i replaced the control-defrost adaptive timer pc board after lighting storm and it worked fine for ten days then i turn off may power to my house to reground the house and my frig is doing the same thing fan not running evap freezing fan not running what is going on
Apr 08, 2008 | Frigidaire FRS23H5AS Side by Side...
Kenmore side by side 59658692890
you kenmore may be held up in defrost . you ll nead to lokate the timer and first try turnig it with a screw driver. sugjest it may be lokated in behind the covers at the rear of the food compartment .
amana is a totaly diferent unit excepy the 9 year old model . lokate you timer as well but you say the compressor runs. if the copressor runs and there is no cold then the must be eather a leak of refrigerant total loss . or inoficient compressor. eather case the fridge this problem is way to expensive to repair and out of woranty. sorry.
kenmore if the timer wasnt the problem now you look at the temp control . it is the one that actualy has an off position. you can try a hard tap with the handle of a screw driver and see if the compressor starts , if not you have to olm it out and see if it has condinuity in the on posision. hope this helps
Mar 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Fridge not getting cold, fan tested and working but not being switched
The fan won't run if the unit is in a "defrost" cycle. It turns the fan and compressor off so the heater can defrost the coils. If the evap fan isn't running and the compressor isn't running then you may be stuck in a defrost cycle. See if you have a defrost timer that can be manually advanced (looks like a screw head that can only turn clockwise direction). It could be located in the frige section on the roof area. Usually a small hole mixed in with other screw holes that you will have to look up into and see the clock dial screw head. If you find that, manually turn the screw (it will click as notches go by) until you can hear the compressor and fan turn on. If that happens you likely have a bad defrost timer. If you have an "adaptive" defrost unit it will be a small circuit board that controls the defrost cycle and you will have to replace the board.
Nov 24, 2006 | Hotpoint FFA90 Bottom Freezer Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
223 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
