Question about Denon AVR-1907 Receiver
Component video terminals
How do you select this for the DVD player connected to it?
  • jtwhitlock Jan 25, 2008
    I have done that, but no audio is heard through the system. How do I get the recieverr to recognize the connection?
    Guru:
  • 1,894 Answers
Just connect both by cables provided
Posted on Jan 25, 2008
  • dewan nafees ahmed Jan 25, 2008
    hey brother you cant make it recongnise it. it must recongnse itself..
    first of all check if you have done all connections right..
    even after that if you are not able to hear then check with the recivers manual.. if your player and reciever are compatiable with each other..
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
Jul 24, 2013 | Sylvania SDVD7014BJ 7 in. Portable DVD...
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
Hi, I have a brand new blu ray player, have set it to bitstream, and am attempting to use an optical audio cable, which does not work. The coax analog works fine but cannot get sound. I see in manual...
Instructions from manual
This receiver is equipped with two DIGITAL IN terminals-one digital coaxial terminal and one digital optical terminal.
You can connect any component to one of the digital terminals using a digital coaxial cable (not supplied) or digital optical cable (not supplied).
IMPORTANT:
• When connecting a video component using the digital terminal, you also need to connect it to the video jack on the rear. Without connecting it to the video jack, you cannot view the playback picture.
• After connecting the components using the DIGITAL IN terminals, correctly set the following if necessary:
- Set the digital input (DIGITAL IN) terminal setting correctly. For details, see "Selecting the Digital Input Terminals-DIGITAL IN" on page 16.
- Select the digital input mode correctly. For details, see "Selecting the Analog or Digital Input Mode" on page 17
The rest can be found on the link below. NOTE the page numbers referrer to the manual pages NOT the pages numbers on the site.
JVC RX 5032VSL Instructions Manual Selecting The Analog Or Digital Input...
Nov 10, 2017 | JVC RX-6030V Receiver
Hi, I have connected component leads from my dvd
Enable the component output on the DVD player menu. Sometimes the component output is shared between RGB/S-Video/Component, make sure you select Y/Pb/Pr on the player's menu.
Nov 04, 2009 | Sony DVP-NS51P DVD Player
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
How do I connect my dvd to my tv???
connect component{red, green, blue} cables to corresponding color on back of tv or yellow, red, white cable to back or front of tv and select input on remote. May be component labeled or video 1, 2 and etc...Make sure dvd player is turned on first.
Aug 04, 2009 | Panasonic DVD-RV32 DVD Player
My DVD player quit working. It was plugged into my Yamaha amp. I hooked up another dvd player, I get sound and no picture. When the dvd player is connected directly into the TV there is picture & sound. I...
Try using the composite video or SVHS video outputs on the original DVD player with the Yamaha amp. The other DVD player might have a switch on the back to select composite or component video outputs.
Dec 13, 2008 | Audio Players & Recorders
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
Denon AVR-1907 Receiver Logo
35 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
