Question about HP Officejet 7210 All-In-One InkJet Printer
Problem: Only printing Black/Greyscale
Where is the control to change from B&W/Greyscale to full color printing? The printer is only printing B&W/Greyscale from one computer, but full color on another computer, so it must be a software control on the computer but I cannot find it!
Please help!
  • ivorythumper Feb 02, 2008
    Thanks G-Man! I went ahead and removed and reinstalled the printer drivers from the OEM disk, which solved the problem. I appreciate the response!
    Steve
  • 16 Answers
The printer software has probably been set to print in grayscale. Follow the steps below to check this setting:
  1. In the software application being printed from, click File , then Print . The Print dialog opens.
  2. Make sure the correct printer is selected, then click Preferences . The printer Preferences dialog opens.
  3. Select the Color tab, then make sure that Print in grayscale is not selected
Please let me know if still you cant print color. Its intresting. :)
Posted on Feb 01, 2008
Canon Printer MP250 doesn't want to keep the grayscale ONLY setting.many attempts to use only black ink but it keeps on setting color ink by default. SB001
If you are changing to greyscale before you print, it will only stay there for that print job. You need to go to the printer through the control panel - devices - printer and change it to greyscale. It should stay that way then.
Jul 03, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
Prints blacks fine, not printing grayscale.
Hi:
The answer to your question is very simple. If your document has a greyscale area, it is a color document and needs a color printer to print.
Greyscale is not light black printing, it is color in layers to give the visual impression of light black or grey.
Greyscale printing is only printable in a color printer, and does not use any black ink in its reproduction.
Sorry.
Mar 16, 2015 | HP LaserJet 2430n Printer
CANON mp 830 NOT PRINTING BLACK EVEN THOUGH BOTH BLACK INK CARTRIDGE IS HALF FULL. i have taken the print head out, cleaned the contacts and still the same. what else can I do?
Copy machine makers are notorius for forcing users to use a bit of the more expensive color mixed in with black. I can't print in black, it is called greyscale, therefore it has color in it. If you only print in greyscale, you'll notice your color cartridges going lower over time.
Mar 01, 2013 | Canon PIXMA MP830 All-In-One InkJet...
Printer will not print in color, only black. We just replaced the cartridges.
If its an HP inkjet printer you may have set it to print in black and white. To change this setting go to "control panel", then "printers and devices", right click on your printer, then "printing preferences", "advanced", then uncheck "print in greyscale"......Good luck !
Nov 03, 2012 | HP DeskJet 932c InkJet Printer
I have a hp 3310 wireless. It prints in colour well but if you print in black most will be not clear although a line every so often is printed clearly. If you print the same document the same lines...
What you are trying to print is created in RGB. This means it is a photo that has been created in a color format that will ONLY print if you print it in full color. If you try to print your photo item in only black, it will only print what it sees in TV Colors, a combination of RED GREEN BLUE. This is why you will only get part of the image printed when only in black.
The only way to change it to print the whole image in all black, is to open the image you are trying to print in Photoshop or another professional grade photo program, and to change the settings of the image to CMYK, effectively, Cyan, Magenta, Yellow, Black. Then, change the image once again - to GREYSCALE. This will effectively change all the colors to a SHADE OF GREY, in different HUES.
Save the picture as a JPEG, and then print from the desktop, from your picture viewing software that came with your computer, and you will see everything print out from the black ink, in greyscale.
Nov 16, 2010 | HP Photosmart 3310 Printer
Why will my HP Photosmart 8250 not print in greyscale when one of the color tanks is empty, there is plenty of black ink.
Greyscale in obtained by using shades of color; meaning that all color (Cyan, Magenta, Yellow) tanks must be full.
Nov 07, 2010 | HP Photosmart 8250 InkJet Printer
Wont print in colour
Check the printer settings in "Control Panel", "Printers" are not set to "Greyscale" or "Black & White".
Sep 16, 2009 | Lexmark Color Z45 InkJet
Print in black ink only
I know you can print in Greyscale which prints in black and white only. On your Windows computer, you should just be able to click Start -> Printers and Faxes, then right-click your printer and choose Printing Preferences. Look for a tab that says Color and click it. There should be a selection, probably a check box, that lets you choose "Print in Greyscale". Afterwards, when you print, even color documents will print in black-and-white only.
Oct 07, 2008 | HP Photosmart D7160 InkJet Printer
Printing in color
hi
often the printer 'driver' settings on your printer are set to greyscale only
on the pc open the control panel, printers
right click on the printer and select properties
open the control for the printer and go to the printing preferences (on the general tab)
on the next window (main) look down and ensure the setting is set to colour (not greyscale)
ok out and try printing again
these settings are from my iP5000 and should be similar
try looking in the preferences for similar options
D
Nov 21, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Print Black and White?
When choosing greyscale you should also have the option to "print using black print only" I am assuming you are using WIN XP START BUTTON CONTROL PANEL PRINTERS select the default printer right mouse click select properties select the printing preferences button select the color tab check the greyscale box the below that select the print in black ink only. I know this works because I just set it up for a customer yesterday. Good Luck, Tim
Feb 06, 2007 | Brother MFC-5440CN All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
