Question about Acer Aspire 5610-4648 Notebook
Touch pad is not working in my computer laptop
How can I solve this problem touch pad is not working
  • jadajohn Jan 25, 2008
    what can I do now no body can solve this problem at all I love use touch pad it just easy and soft
  • Anonymous Feb 13, 2008
    My touch pad and my arrows are not working at all on my laptop. Cant figure out what my daughter did to it,can you please help me> Thanks Kim
    Genius:
  • 1,067 Answers
Ya i know your poor fingers we can replace that mouse pad controler under the top panel 25 on ebay fr the part for your model
Posted on Jan 25, 2008
  • 2 more comments
  • Anonymous Jan 25, 2008
    its turned on also right u dint turn it off by acdent button above it
    thats what u have to do tho replace it ok du hello on ebay ok buy the touch pad part do u know how to install one if not have tech do it
  • Anonymous Jan 26, 2008
    TOLD U HOW TO SOLVE IT ITS BROKE CANT FIX THEM ONCE THEY GO U CAN REPLACE THE UNIT THO SQUARE BUY THE PART ONE EBAY MAN OK 15 BUCKS INSTALL IT EASY TO DO IF U NEED HELP ASK ME OPEN FOR CHAT
  • Anonymous Jan 27, 2008
    u have to buy new one like i said on ebay or take labtop aprt cheak see if ribbin cable has came disconected from mobo ok if not buy new pad they sell 20 bucks that part for u easy to installl
    change this feedback for helpfull cuse this is helpfull info for your deal man
6ya staff
SOURCE:
Anonymous
  • 127 Answers
SOURCE: touch pad scrolling is not working
your synaptics software isn`t working.goto start - run type msconfig.goto services & enable it.do the same on start up & restart your comp.
if it doesn`t work then use the driver cd that came with the laptop
Posted on Jun 13, 2009
Santhosh_7
Satya Santhosh
  • 233 Answers
SOURCE: Touch pad stopped working
I recommend you to uninstall and reinstall touchpad drivers to isolate the issue.
Press Windows key and R. Type devmgmt.msc in Run window and click on OK. Click on "+" sign beside Mice and other pointing devices in Device Manager.
Right click on Touchpad and select Uninstall.
You will be prompted to restart the computer.
Windows detects touchpad and the touchpad drivers will be reinstalled automatically.
You can also install touchpad drivers from your notebook support website.
You can reinstall the drivers from the below links:
http://support.acer-euro.com/drivers/notebook/as_5920.html
http://www.laptops-drivers.com/acer-notebooks/download-drivers-acer-aspire-5920-notebooks.html
However I suggest you to install the drivers by visiting the acer support website.
Also perform windows update.
Posted on Jun 29, 2009
parrotheadpc
Chip
  • 2600 Answers
SOURCE: Touch Pad on my laptop is not working
Follow the guide below to tear the laptop down, you are extremely fortunate that the device is even working. Electronic sircuits and water have never been a good match, and your keyboard and touchpad are essentially just large electronic circuits. There is probably some water still somewhere under the keyboard and it is probably in contact with the tochpad cable or socket. When you have the keyboard off, use a hair dryer on warm and completely dry out all components and make sure all the small flat cables are tight in their sockets.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Posted on Dec 14, 2009
Electronics Repair
  • 452 Answers
SOURCE: my laptop easynote NJ75 ..mouse pointer is not working
Replaced it or get an external USB mouse.
Posted on May 04, 2010
rcw1962
Roy
  • 2571 Answers
SOURCE: Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Posted on Jul 10, 2010
My wipro BM49XX touch pad is not working how to solve
If the touch pad is not working I would recommend buying a mouse that can be connected via a usb port. Mouses of this sort can be found as cheap as 1$
Nov 05, 2013 | Computers & Internet
I have a hp copaq laptop and the touch pad dont work what shall i do.
This is a common problem for most laptops.
With my experience in HP laptops, you can reinstall the touch pad drivers. Visit the HP website and click on the support link, select the model of your laptop under the 'Drivers' section and download the touch pad drivers for your model.
If that does not solve your problem, buy an external USB mouse for your laptop, that is the best alternative solution most people with touch pad problems resort to.
Thank you for using Fixya,
Kenneth
Jul 25, 2011 | HP Compaq 6720s Notebook
My touch pad can't click
Using only the keyboard navigate to the internet and google 'Touchpad Driver' download whatever comes up. the exact same thing happend to mine. you may have accidently erased it while cleaning up your computer.
Jul 04, 2011 | Toshiba Computers & Internet
Touch pad does not operate. have uninstalled and reinstalled correct driver and PC device manager says device is working properly with no conflicting programs. generally, the pad did not really operate...
it is possible that the touch pad is disabled. Check control panel to actually confirm.
Since your touch pad is not operating, you will need an external mouse to perform this task.
Here is what you have to do to check if the touch pad is disabled.
Turn on your laptop, wait till it boots completely.
Click start,
Scroll to Control Panel select Control Panel.
Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
On the dialogue box, click "Device settings".
Under device settings, you will find "Synaptics Touchpad..."
Highlight the "Synaptics Touchpad..." by clicking on it once, then click enable.
By now the mouse pad should be enabled. Apply the changes for it to take affect.
If the above doesn't solve the problem, try performing system. System restore can help to back date your computer to the time when the touch pad was working....
Go to Start > All programs > Accessories > System tools > System restore. Read and follow instructions.....
If the two solutions does not work, please let me so that I can further help you.
Yours sincerely.
Elect_Comp.
May 26, 2011 | HP G60-120US Laptop
My acer aspire one d255 ,touch pad is not working properly. able to move the mouse pointer , but not able to click using touch pad
Sounds like the touch pad may be bad or isn't installed.If you look under hardware and it installed then most likely the touch pad may be bad.
Jan 10, 2011 | Acer Computers & Internet
Lenovo touch pad not working properly
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
May 27, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Gateway notebook touchpad
Thank you mewms_14904. The problem was the F key. In my case it was F7 that enables and disables the glide pad of my notebook.By pressing fn key and then F7 solved my case.
Apr 16, 2008 | Gateway MT3705 Notebook
Computer Frozen, Touch pad not working
there is a switch nearby that orange light or the light may be a switch. press on it then the color of light will change and ur problem will be solve....thats all
Dec 21, 2007 | HP Pavillion ZV6000 Notebook
Acer Aspire 5610-4648 Notebook Logo
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
