Question about Refrigerators
Refrigerator/freezer gets warm intermittently
I have a 7-year old GE side by side refrigerator, model TFX26PPDAWW. The freezer/refrigerator intermittently gets warm. It appears that the compressor does not always come back on when needed for some reason. However, if you manually turn the freezer control down and back up, the compressor always comes right on and everything cools back down just fine. It may go a week or two without a problem, then the problem may occur once or twice a day. The compressor does not seem to get abnormally warm when it runs.
GE Service came out and cleaned the compressor coils, but that did not solve the problem.
  • Yoxi II Apr 09, 2008
    My 5 years old GE top freezer has the same problem. It cools for 2 days to 5 days until some frosty build up on the food, then the fan starts to blow to warm up the compartment. I have to unplug the power, wait about a couple of hours, and then plug the power cord back in, the freezer starts cool again. What should I do to fix it? Replace the thermostator? Are thermostartor and thermistor FF the same thing? Thanks!
  • 105 Answers
Sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Posted on Jan 25, 2008
My Beko fridge freezer is rubbish all the food has been heated up it's smelly and makes chirping sounds at me :( It won't cool down insists on being warming regardless of the thermostat setting. 3 days it's been like that now and the food in the freezer compartment looks like a chenobyl aftermath.
Posted on Aug 04, 2008
2 Suggested Answers
6ya staff
SOURCE:
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: My refrigerator/freezer intermittently gets warm
GE had a problem with their units I dont see which model you have here but if you pull the unit out and look on the back wall lower right side and see a cover plate with about 10 screws in it ther is a main ctrl board in the and it controls just about everything in your unit There is a relay on the board that controls the compresser as well it maybe sticking at times. The crappy part is you can not just replace the relay you have to replace the whole board.. if this is the case post the model # and i will get you the part# and cost on a replacwement it is something you can do yourself
Posted on Jan 24, 2008
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
GE side-by-side refrigerator tfx26ppdaww freezer cold, frost on back wall, fridge side warm, is it the damper? or something to do with the frost?
The Thermostat Defrost its not working anymore, it doesn't defrost anymore and it acumulate ice on the gap that flows the is in between the fridge and the freezer. so what you got to do is defrost your refrigerator and remove the back wall, and locate the defrost, cut it and take it to an appliance part store, and get a new one and just put it back and it should work like new!! :)
Jan 14, 2011 | GE Refrigerators
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
May 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Not Cooling
Hi , the refrigerator having problem with enfeller fan stuck it needed to defrost manually to drain all ice buildup inlet of refridgerator hole after 3 hour try start refrigerator.
Feb 05, 2008 | GE GSS25JEMWW Side by Side
Jan 24, 2008 | Refrigerators
Refrigerators Logo
4,928 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
