Question about Kirby G4 Bagged Upright Vacuum
Belt replacement i am trying to replace the belt on my kirby g4 and i can not get the rooler off to replace the belt. if you could tell me how to do this it would be great.
  • 5 more comments
  • lilnes Feb 21, 2008
    i do not know how too change the belt
  • kirbylover Jun 25, 2008
    read domvacs solution but for some reason still can't get it to go on right. When I get the belt hooked on to the hooked on the other side and put it back on the machine and start to turn it to the BELT ON, green arrows lined up position, the knob with not turn far enough to let the green arrows line up. This is less than a year old and has only been used about 10 times and never been serviced because the place that sold it to me went out of business and there are no local dealers around here. I am in a very rural part of eastern Kentucky. About 65 miles east of Lexington. Any help would be greatly appreciated.
  • luismonet Sep 27, 2008
    is the heritage 2 the same with the magnet on the roller
  • bobhoward15 Nov 30, 2008
    cant get my belt back on
  • Anonymous Dec 22, 2008
    how do you alltached the belt on a kirby vacuum?
  • Anonymous Jan 01, 2009
    i have the same promblem please help
  • christine_74 Jan 01, 2009
    i have same prob
  • 126 Answers
Lift the light bulb housing up and you will find a latch that will rotate to release the front agitator housing and remove it from the machine. On the bottom of that housing, there are two latches that secure the bottom plate that covers the roller. Remove the plate and the roller will come out. Be sure to notice that the roller has a magnet at one end that lines up with the indicator that shows you when the roller is turning - it's the little green light that glows while you are vacuuming. The roller needs to go back in the same way it came out. O.K. Take your new belt and position it around the middle of the roller and drop the roller back into place and replace the bottom plate. On the front of the housing, there is a big square "knob" and you can rotate that piece. If you look inside the hole on the other side of the agitator housing, you will see that there is an arm that moves with the square knob. The end of this arm will catch the belt and with a little effort, the knob will rotate and lift the belt into position for replacing the housing back on to the machine. once you have the housing back on the machine and secure, you rotate the square knob back around and the belt will sit down on the drive shaft. If you look at the top of the agitator housing just above where the knob is, you will see a red and a green arrow which indicate which way the knob turns to do the "remove" belt or "replace" belt. I hope this helps. Once you do it properly, it actually is quite easy.
Rating
Posted on Jan 27, 2008
Kirby G4 running very loud and smells hot.
were you put the belt on see if any thing is rubbing against shaft.it may have been the belt,replace the belt and clean out the bab and also the floor brush.
Jul 31, 2010 | Kirby G4 Bagged Upright Vacuum
Green light no on
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt2_bing.gif has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial2_bing.gif that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Video Repair on How To Check The Belt on a Kirby Generation G4:
I hope this was helpful! If you have any follow up questions, please feel free to use the comment field here on Fixya.
If you need to purchase a new roller brush, or belt for your Kirby G4, here are direct links to those parts on our website:
Kirby G4 Roller Brush Assembly:
http://www.govacuum.com/kir108.html
Kirby G4 Agitator Belt:
http://www.govacuum.com/kir143.html
If this repair was helpful to you, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when someone answers your questions.
Thanks again,
Chris Jones
GoVacuum.com
May 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How do you change the belt on a kirby g4 vacum
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners, including your Generation 4, G4. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Thanks for watching!
Chris J.
Feb 20, 2010 | Kirby G4 Bagged Upright Vacuum
How do I replace the drive belt on a kirby G4? Actually the belt is already replaced I just need to know how to reattach that front part back onto the main vacuum. HELP
Greetings from GoVacuum,
Here's a video we shot showing you in detail how to install a belt properly, and how to reattach the head properly. I hope this helps you;
Jan 30, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 causes black streaking when shampooing carpet
Replace the belt it is probably worn. You can get a replacement here:
Kirby G4 Belt
Dec 06, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hello
here is a link to a site with detailed instructions on replacing the belt on your kirby
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
hope this helps!!!
Apr 06, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
333 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
