Question about Refrigerators
GE profile refrigerator model # TBX25PR
I have a GE profile refrigerator w/ ice maker (TBX25PR). The ice maker dispenser isn't working. It makes ice but when you push the door button you hear the motor but ice does not dispense. It seems the ice maker drive mechanism is not rotating. It worked in the morning and then it just stopped. I tried to rotate the drive mechanism but it seems stuck. What can I do? It is a pain because to get ice you have to completely remove the ice container- a very poor design.
  • 3 more comments
  • Anonymous Nov 01, 2008
    The drive mechaism will not turn when the ice container is empty. The motor turns on though
  • Anonymous Dec 09, 2008
    My problem is slightly different. The motor is not working. The refrig does not dispense ice when the lever is pushed
  • Anonymous Mar 16, 2014
    how to remove ice maker samsung refrigerator RS265TDBP
  • Anonymous Mar 23, 2014
    Model # ED5LHAWQ00
  • Anonymous Mar 29, 2014
    I push the ice button hear the rotation, but ice is not coming out
    Problem Solver:
  • 10 Answers
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Posted on Jan 25, 2008
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice machine not working
inside your dispenser, on the front door it is solenoid valve, it got rusty and stock slosed so you need to replaced is a common problem for GE Profile..about $20 for part can be messy but i hope you can handle it
Aug 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker will not work, Ge profile Arctica.
Here you dad had the same issues...Good Luck!
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
1,465 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
