Question about Sony SLV-N750 VHS/S-VHS playback VCR
I have a Sony SLV-EZ717
My parents taped a program for my son. When we play it back on our vcr it seems to be in fast forward mode. The voices are like chipmunks and the vision is just black and white lines.
This has happened before. I do not know what to do to play it correctly
Thanks
  • tommo11 Jan 25, 2008
    Thanks so much for that - I thought there was something I could do to fix the one I have.
    I will try to get my parents to tape on a different speed.
    Thanks again
    New Friend:
    Problem Solver:
  • 8 Answers
This model has long play. Try adjusting the track, there should be buttons on the front of the unit.
Posted on Nov 26, 2013
  • 2,334 Answers
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Posted on Jan 25, 2008
Tape is playing back in fast forward only
It is possible the tape loaded on the wrong side of the drive. If you romove the tape, look for slack and tighten up, try it again or another tape. Otherwise it is likely that a spring for the pressure roller is off or broken. This is not easially repairable.
Oct 19, 2011 | Sony M-670V Handheld Cassette Voice...
VCR transmits audio but no video to TV following lightning strike
pls check your SONY vcr back side pin cofogratin .
video in / out
audio in / out
3 MORE VIDEO OUT PIN [GY /BU / RV ] green /blue /red
if yes then use this three pin .but check your tv set back side same three pin is there .
if not
cont. me :e-mail :shaiparikh@yahoo.co.in .
pls send me your tv model no /vcr model no
Oct 08, 2009 | Sony Televison & Video
Sony VCR ''Eats the Tape'' Model SLV-N750. It plays and records but doesn't release tape. It does not repond after I try to run forward or back and does not advance on ''Play'' but shuts off. Is there any...
If this unit is 4-7 years old then TOSS it. As time goes by the rubber gets soft and the units timing gets whacked. Repair will be more than what it's worth , unless your emotionally attached to it ...
Please rate!
Mar 13, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
May 30, 2008 | Televison & Video
VCR SLV-640HF
The mode switch is the device that monitors the various positions of all mechanical components in the transport area. It is usually an encoder type device, located near the center or right side bottom of the transport. But, before I'd condemn the switch, I would certainly check and see the the transport is "cycling", and that nothing is slipping. This is usually the case when this symptom crops up...accordianman
May 13, 2008 | Sony SLV-640HF VHS VCR
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Jan 27, 2007 | Sony SLV-940HF VCR
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Sony SLV-N750 VHS/S-VHS playback VCR Logo
287 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
