Question about Mitsubishi WS-65611 65" Rear Projection Television
WS-65611 PIP worked until cable tech connected new Digital Box
We had PIP even after the Southwestern cable tech setup out Digital Box. I had some minor problem with the digital box and remote and a new tech came out. He said the connections in the back were not setup correctly, so he added a better cable from the wall and a special booster. After that we no longer can use PIP.
We love PIP since the 65" in PIP is like having to 32" tv. Great when I watch sports. Is it true that PIP will not work in High Def? If so is there anything I can do to change it?
Thanks .. Brenda in Sunny California
  • rohara Jan 25, 2008
    I want to PIP to be able to have my TiVo on one screen and my cable box on the other. I do not care about the DVD.
    If I cannot have Tivo then just regular cable TV without going through the Digital box.
    thanks .. b
  • Mitsubishi Master
  • 8,617 Answers
Go into your setup menu by doing the followng. make sure all items under setup are checked then onthe PIP/POP menu make sure it is se to ANT A Ch.3. Heres how you get into the setup menu.
A. Option Menu Setup
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "2", "1", "7", "0" in sequence to select
the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
If you need any additional info let me know. Your Pip should work you may need the service manual to set it up properly. Let me know if you do I know where you can get one cheap and it comes with free unlimited support.
Posted on Jan 25, 2008
  • Sonny Berry
    Sonny Berry Jan 25, 2008
    Just split your cable before the box and run that to input a and then you will have regular cable for the PIP source and your HD will be like it is now in the DTV input. That will allow you to have your PIP back.
    Genius:
  • 1,067 Answers
Do u want pip form the cable box itself or watch dvd on one side then tv on other
  • nick helpap
    nick helpap Jan 25, 2008
    ok 2 spetare oinputs then run tvio off s video other on cox cable
Mitsubishi WS-65611 losing HD signal
Not to worry.Its really a Great tv...But...the only thing you should do to fix this just get it hd ready and your and dont get it integrated with an hd receiver and everything will be fine!
Oct 11, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Ws 65611 will not play HD channels. Screen gets fuzzy like it is trying to focus, then converts to blue screen that states "Check connections or power. The connections for RGBHV or YPrPb invalid" I have...
This model only has one HD input---it has two sets of component inputs on the back and one is marked 480/1080----in the menu it will be the DTV input.
Check to make sure you are not connected to the other component input.
Let me know what happens and let me know exactly where you are connected and what are using for signal.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 28, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Tip
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
My ws-65611 always stay in 480i even with HD signal.
If you are using the component connection, make sure you are connected to the one that will support 1080i. If that is not the problem, make sure that the HD receiver is outputting 1080i and not 720p. No RPCRT will support 720p and the video may be down-rezed to 480 since this is the case.
Jan 25, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
Tip
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-65611 65" Rear Projection Television Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
