Hotpoint MAC-130 air conditioner dripping water
We have a near new Hotpoint MAC-130 that we bought new a couple of months ago. We just noticed that it is dripping quite a bit of water which is soaking the carpet around it.
The automatic drain pipe is connected and runs outside and seems to get water running from it, but the tank is filling anyway. I have drained it outside by unplugging the rubber drain bung at the bottom. Within half an hour or so it is dripping water again and the tank has a fair amount of water in it agin. I don't beleive the water is coming out due to the rubber drain leaking or surely the tank wouldn't fill so quickly...
We make sure we keep the washable filter clean.
The unit seems to cool OK and as it always has done...
It is of course under warranty, but I am very curious to find out if there is anything that I can do or check myself...
  • yaabaa Jan 30, 2008
    Thanks for the information, Ranger25.
    The day that I noticed the problem was unusually humid, but I expected that it would have handled that OK without leaking loads of water. I also have a DeLonghi Pinguino and that had no problems at all at the same time - the water tank in it didn't have a drop in it.
    I am just testing the Hotpoint again now (In the bathroom !!) after a few days draining it fully and so far I have not seen any water leaking at all after an hour or so - I will have to keep an eye on it.
    As it is still under warranty, I am not keen to start pulling it apart and voiding the warranty.
    Now my next problem is what to do about the ruined area of carpet from the water damage as it seems that the underlay has expanded and bubbled up in places - after it has dried out, the lumps haven't dissapeared as I hoped they would...
The exact same thing happend to mine. It was the internal water line - a clear plastic tube, that can become kinked, this means that after running a while the water, instead of going to the water tank, or draining outside, backs up and starts leaking outside the unit.
Solution is to simply unkink (straighten) this internal water line. Get the kink out of it and let the water run smoothly down.
Posted on Nov 10, 2011
    Scholar:
  • 72 Answers
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Posted on Jan 27, 2008
Why does the drip pan overflow?
The pan may have been installed incorrectly but it also is possible that debris may be clogging the outlet periodically.
Jul 16, 2015 | Goodman Manufacturing Goodman ARUF182416...
Is the hotpoint mac-130 air conditioner a reverse cycle
The mac 130 does not have a reverse cycle, also known as a heat pump.
Aug 30, 2014 | Heating & Cooling
I have a portable air conditioner - Hotpoint MAC 130 and it blows cold air only rather than cooling down like it used to be. I bought it 5 years old and haven't been using them very often. It still...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Heating & Cooling
Haier air conditioner just bought it a month ago.seems the water isnt draining fast enough out of it.i have it tilted pretty good but keeps spitting water out the front
The newer units do not have drain holes or they have them plugged and you need to knock them out...if there is a knockout it will be in one of the back corners outside...
The newer units are made to evaporate the water and so they do not drip...but in very humid conditions that does not always work effectively...
You can also drill a hole in the pan in the outside back corner, but BE CAREFUL to NOT drill into the condenser coil!!!
I have had many calls to repair coils for this reason!!!
heatman101
Jul 05, 2011 | Haier HW05CA12 Air Conditioner
Hello I have just purchased a secondhand hotpoint MAC 130 airconditioner and it is running well however water is dripping from a black outlet at its base. Should there be a hose which attaches/srews onto...
The bigger hole is a drain plug to quickly empty the unit, it should have a runner bung plug and shouldn't leak, the small tube is all you need to get excess water outside
Feb 03, 2011 | Heating & Cooling
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
Condinsate Water Leaks Inside Trailer
Where is it dripping from inside the trailer? is a tray under the unit filling up? why does the line drip? where from? is it split? have you put a color dye in condensate to check flow what temp have you got inside your trailer when A/C off?
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
1,770 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
