Question about Sony CDP-CA80ES 5-Disc CD Changer
Sound from only one channel
I have a ES series Sony 5-disc CD player. Sound comes out only from the right side speakers. I've switched the speakers cables, plugged in other devices to the recievers CD in connections and narrowed the problem to the CD player itself.
Any suggestions for a quick fix?
  • CaptT Jan 27, 2008
    This was very helpful. Looks like I'll need a d to a convertor.
  • 112 Answers
If there is a headphone output on the unit try listening through it to see if the sound is in both channels. If so,it is likely a dry / fractured solder joint on or near the jack connector. If not it could point to a failure of the digital -> analogue convertor IC chip.
Posted on Jan 25, 2008
  • fluffy cat Jan 28, 2008
    Could be a dry joint on the DAC IC. The IC will also be available as a part from the likes of CPC, RSComponants or even ebay. There is a site called 'DIYAudio' or similar that regualrly has posts about changing DACS usually to 'improve' sound but the theory,techniques and DAC types / suppliers will be relevant if you want to have a go soldering in a new one. You may need to check that all downstream componants after the DAC are still functioning first. If it's ES spec there may be seperate signal paths for each channel. Can you post the model number?
    Offboard DACS in standalone boxes are also available relatively cheaply as they are no longer in fashion. Cambridge Audio did an amazing one that was also an isolation table that stood on 4 soft spongy balls. Can be pciked up for around £40 on ebay.
Purchased a new Sony Bravia TV KDL32R420B. Picture perfect but no sound from Right speaker. Please help!!
Check whether the balance control is settings. Go to the audio menu to both TV and DVD player; and make sure that it is set to Centre position; to both the devices. Still there is no audio with one channel, check it with an other know good disc. Still you can't get sound from one channel, the audio output section to the TV circuit should be checked. Contact any service technician.
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 01, 2014 | Televison & Video
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
Static sound
Try a CD cleaning kit and follow instructions if this fails it is more cost effective to replace the CD changer than have it repaired.
Apr 05, 2012 | Sony CDP-CE275 5-Disc CD Changer
Rowe r92 sound problem
Moving the wire indicates the speakers are OK. Try reversing the 3 pin plug from the cartridge. If the problem stays on the same channel, it is probably a preamp board issue. If the problem switches channels, you have a bad wire to the cartridge or a bad cartridge.
Nov 16, 2011 | Audio Players & Recorders
No sound but reading discs
Every one enjoys listening to music . When CD player stops doing its job we take it to a repair shop. But before doing that we can try out few simple ways to troubleshooting CD player which may save us from paying huge amount for repair.
Troubleshooting involving diagnosis and then fixing it by finding the cause for the problem. First step involves focusing on a specific problematic area . Next step would be to check if the connections are proper and the last step is to troubleshoot. Let us look at each step in detail..
You can start by checking the earphone port,By using an earphone jack,inserting into the earphone port...If no sound comes out from it, that means it's not from the speaker, but from the board of the radio.The sound IC has is damaged and will need to be replaced..
To fix these,you might need to contact a repair man.
But, if sound comes out from the earphone jack, That means it's a minor case,it will be a problem from the speaker of the Mini Disc Player.
Checking the speaker connection..You might need to open up the speaker
Test the speaker by using a AA battery with small wires on the positive and negative side of the speaker. If sound comes out,that means i wire has cut or remove from somewhere inside the speaker, But if still no sound coming out,That means will go back to IC on the bard of the radio..
Keep me posted when your done checking..
Thanks for using fixya
Aug 07, 2011 | Sony MDS-JE330 Mini Disc Player
Sony CDP-CX455
did you have any luck with swapping the channels to determine if which is bad, cd or system?
Mar 28, 2008 | Sony CDP-CX210 200-Disc CD Changer
Not good sound comes frm my Altec Lansing 251i speaker
1. you first check with other media player software and use another mediaplyer software checkit this problem, if u experience the same
2. check the the dvd disc is supported the 6 channel, use another 5.1 dvd disc
Jan 04, 2008 | Audio Players & Recorders
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Look for a loose connector on the back of the radio. If it is not fully seated in the radio, all sorts of goofy problems happen.
Apr 15, 2017 | JVC CH-X1100RF 12-Disc CD Changer
Sony CDP-CA80ES 5-Disc CD Changer Logo
265 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
