Question about Microwave Ovens
Removing microwave waveguide cover
i have a GE 1860 microwave that has sparking from the waveguide cover. Reading the posts, it seems that it would be a good idea for me to remove the cover and thoroughly clean that as that might solve the issue. My microwave is mounted under a cabinet and is itself in a large cabinet held by a frame. Two questions though
a) the wave guide cover is held in place by two rivet like things that I'm not sure how to remove. Pry them off? and if so, how would i put those back in?
b) I read somewhere that there I need to discharge a capacitor before I open the cover as I might otherwise shock myself. Is this true? and if so how do I go about doing this?
Thanks!
  • 3 more comments
  • okaab Jan 25, 2008
    Thanks for the reply. I actually wasn't asking about removing the waveguide per se, but the waveguide cover, as there ware other posts on this that suggest that food particles / grease may have gotten on to or behind the cover, causing carbonization and sparking. The suggestion was to remove the cover and clean it thoroughly as that may alleviate the issue. My original questions above were with that intention in mind. How do I remove the cover with those "rivet" like things holding it and do I need to worry about the capacitor when i do so?
    Thanks!
  • okaab Jan 26, 2008
    Thank you very much. I removed the waveguide cover and it did have some gunk under the sides which I cleaned. I also noticed some black (burn?) marks on the metal behind the waveguide cover which i managed to clean somewhat. Hope that those marks were a result of the carbonization of food particles v/s something else wrong with the magnetron or waveguide. Anyway, hope that this cleaning helps eliminate the occasional sparking that I have been seeing. Thanks again for your help.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Not a good idea to be messing around the waveguide of a microwave oven. The waveguide is covered with a protective coating (usually a special paint) that aids in wave propagation. Usually when sparking occurs inside a waveguide it's due to the magnetron misfiring. If operated in this condition for extensive periods of time, the waveguide coating can become damaged from arcing and is non-repairable. You cannot simply repaint or clean a waveguide to get rid of this problem. Replacing the magnetron at this point (even if bad) will not correct the problem either. The unit will continue to arc, because the protective coating is burned off in areas. I haven't heard anywhere that you could restore a waveguide in the manner you are describing. In addition, if you disassemble a waveguide you run the possibility of introducing foreign matter like dust and lint, or possibly damaging the interior surface of the waveguide itself which can make the problem worse. The capacitor you are describing is in the high voltage network near the magnetron. Voltage potentials in this area of the oven are around 13,000 volts and higher. That's why it is shielded and has multiple warning labels posted. Some units come with special temper resistant screws to prevent consumers from gaining access to this area. In a nut shell, if you suspect you have a bad waveguide, the microwave is considered non-repairable with some lower end models. On the higher end scale, you may be able to replace the waveguide. I could not cross reference any parts with the model number you provided. If you can list your correct model number (located near the door opening), I can see if your waveguide is replaceable. If you aren't savvy in electronics this is NOT the appliance to be cutting your teeth on. You could easily hurt yourself in the process if you aren't careful. One last thing...some manufacturers may warrant the waveguide or magnetron for an extended period beyond the usual one-year limited warranty you usually get with appliance purchases. If you still have an active warranty you may want to check into this as well.
  • lhord sam
    lhord sam Dec 29, 2013
    hey there, i've tampered the mica plate which is covering the wave guide.. is this a serious matter? kindly help me..
  • Anonymous Mar 31, 2014
    Do i need to replace my waveguide cover that is burnt? Or can I simply remove the cover and continue using my microwave?
  • 5,911 Answers
Okay...if you are talking about the center cover that fits in either the overhead of the microwave cavity, or along one of the walls, those rivet like things you mentioned, are plastic and the center locking pin simply pulls out with the aid of a small screwdriver. Once you carefully pull the locking pin out until it stops, take the same small screwdriver and use it to gently pry around the outer ring and the locking tab should come right out. If you are careful you should be able reuse them. I have done this before. Try to avoid handling the interior of the waveguide itself. Look for any scorch marks. Some discoloration is normal (kind of like a gray streaking color). However, if it is burned excessively, the waveguide is probably shot. The high voltage capacitor is not located near the waveguide cover, so you should not have to worry about discharging it. It is located BEFORE the magnetron. Unplug the microwave oven as a safeguard. I hope this helps you.
Posted on Jan 25, 2008
  • Jeff Rockwell
    Jeff Rockwell Jan 26, 2008
    Some discoloration is normal. As long as the surface coating of the waveguide is not damaged to the point where bare metal is showing, you should be okay. If the unit continues to spark after this you may have a magentron that's beginning to exhibit signs of wear (just some food for thought). Glad I could have helped you.
I ordered a replacement waveguide cover for my kenmore microwave. It did have a small square cardboard like cover. The new on is two plastic pieces but the screws are too short..any suggestions
Posted on Feb 16, 2008
Looking for a service manual for R-207KK
Posted on May 15, 2012
6ya staff
SOURCE:
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Panasonic genius sensor 1250w
follow this test and fix it. God bless you
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Oct 27, 2013 | Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Sparking in microwave (aftron make)
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aaus0Uj3
Jul 30, 2013 | Microwave Ovens
Oven aftron
follow this steps and fix it. God bless you
Brown spots on window of microwave
see this steps and fix it.God bless you
  • Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  • Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  • Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aSjW5F9U
    Jul 29, 2013 | Microwave Ovens
    Rust or brown spots on window of microwave
    Microwave when turn on making a noise and sparks comin from fan area?
    Waveguide Cover
    Rack Support
    Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
    Splashes inside waveguide?
    Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
    The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
    In some models it is the plastic ceiling.
    It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
    The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
    If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
    Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
    If your waveguide cover is burned, it will need to be replaced.
    If you need more specific help, please reply back with your brand and full model number.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    William E. Miller, AS-EET
    [email protected]
    http://www.microwavedisplay.com
    Feb 01, 2009 | GE Advantium SCA2000B Microwave Oven
    Microwave ovens
    The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
    Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
    Microwave Ovens Logo
    7,359 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
