Question about Teac AD-600 3-Disc CD Changer
CD will not rotate.
The cassette player works fine. When you put a CD in, the door will close as normal, but the CD will not rotate. This applies to all 3 trays.
  • 112 Answers
The spindle motor may have failed. Can you try 'starting it off' by hand after inserting a CD?
Posted on Jan 25, 2008
    Scholar:
  • 137 Answers
This fault is probably a dirty laser. Most propriatory cleaning discs will not do a good enough job. you will need to open the unit and clean the laser manualy with a cotton bud and some window cleaning soloution.
Spray one end of the cotton bud with the window cleaning soloution and flick off the excess. gently wipe the cotton bud all around the laser lens and then use the other end of the cotton bud to polish the lens.
Posted on Oct 18, 2010
Getting my aiwa to play cds or cassettes. Bought second hand no instructions .lights up won't play can I get instructions on how to get sound?
You don't state the model, so we are running blind here. It should be fairly obvious. For the CD press the CD button. Then press the door button and put the CD on the tray. Then press play or the door button again. If the CD player works it should play the music. Same with the cassette. Drop the cassette into the holder, push it back in place then press play.
Oct 07, 2017 | Aiwa Audio Players & Recorders
Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Jun 01, 2008 | Audio Players & Recorders
Does battery have to be charged for eject button to work
there are a few different systems that they use but most are like a cassette player that is spring loaded and the door will open with out power and you can remove the tape if its like a CD system same rules applies unless it is a sliding tray like a playstation 3 uses or a CD player in most HI FI systems you need power to eject the later
Jun 23, 2012 | Video Cameras
Dvd will not eject from jvc hr xvc27u dvd player all it will do is display the word read on the screen
elsombro is right. There is a little whitish plastic square on the right side of the player, part of the DVD assembly (after you take off the cover). It's about 1/4 inch square. With the unit turned on, push that square with a pen about 3/4 of an inch in or as far as it will go. There will be a clunking sound but that is the sound of the DVD being released back onto the tray. Now gently push the back of the tray forward, ejecting the disk manually. Take the disk out and then press the close button. If the door doesn't close, it's out too far so manually push it in about an inch or so and then press the close button again. Should be fine after that. I think my problem was a DVD I recorded on my computer and it has the wrong format or something. After I got it out I put a regular DVD back in and everything was fine.
Dec 30, 2009 | JVC HR-XVC27U DVD Player/VCR
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
Literally overnight my CD player will not read my CD's
Remind granmama to put the CD's in right side up.
Mar 22, 2009 | RCA Audio Players & Recorders
CD player not turning
the tray should have a micro switch to touch when its closed. maybe it needs some fine adjustment. if it doesnt say closed then the laser drive wont start. or maybe the magnetic clamp hasnt come down onto the disc properly
Nov 09, 2017 | Audio Players & Recorders
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
Teac AD-600 3-Disc CD Changer Logo
275 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
