Question about Dryers
My electric dryer was making chirping noise, dried the clothes inside it but the drum would not rotate for the next load. I took the top off. it looks like the belt has wandered to the middle of the drum, but I can't seem to get into the bottom of the machine to make sure the pulleys are all okay and aligned. what should I do?
    Scholar:
  • 72 Answers
Flip it on its back and see if you can get to it from there. If not, then you have to remove the back cover, which is very tedious with some dryers.
Posted on Jan 27, 2008
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
My Maytag Performa electric dryer heats and tumbles, but the clothes take multiple cycles to dry, and water is pooling next to the left front foot. We cleaned the vent, replaced the vent hose, and opened...
two things come to mind; 1. although drum is rotating perhaps it is slipping under load. Change drum belt, and, 2. perhaps the problem isn't in the dryer, it could be that your washer is not spinning out properly leaving an inordinate amount of water in your clothes which would tax the performance of the dryer. Just a thought. good luck!
Aug 19, 2013 | Dryers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Affinity dryer less than 2 yrs. old will not turn. It hums, but the drum will not turn.
Please check if there's something stuck outside the rotating drum. Sometimes small cloth escapes out of the drum during drying and gets stuck in the rotating shaft. Just try to reach the back side fo the rotating drum inside and make sure that there's no cloth that's stucked inside. Please make sure that you unplug the cord first.
If in case that you did not find anything, you may have a busted capacitor or worse, the motor is defective. It could be that the motor windings are shorted or a bad bushing.
Hope this helps.
Oct 23, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My dryer makes a groaning noise on each rotation ... especially the load is very light. I manually turn the drum clock-wise and it seems to help for while. If we add more clothing to the load it also help....
The belt that rotes the drum has a belt tensioner that keeps the belt tightly fitted on the drum. You may have a dried up belt or a dried up bearing in the roller for the belt tensioner. An inspection can be done by removing the top and front panel of your dryer to see
May 08, 2010 | Dryers
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
G. E. Electric Dryer - on drying rotation making noise
Drum bearing is worn out and needs replacing. There is an axle on the drum that goes into this bearing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | GE DBSR453EBWW Electric Dryer
Clothes Dryer in need of repair
if you look inside the drum can you see 3 screws? if you are mssing 2 then it will klunk.
Aug 06, 2008 | Frigidaire FEQ332E Electric Dryer
Neptune dryer
sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
91 people viewed this question
Top Dryers Experts
