Question about ASUS P5PE-VM Motherboard
450 Watt power supply not enough?
Mobo fully loaded with both sata drives and a dvd and a cd drive. Do I need to upgrade my power supply? I now have problems in mid start up.
    Problem Solver:
  • 18 Answers
No, 450 watts should be plenty unless you're running like 4 hard drives, and a quad core, and a ton of RAM and a huge graphics card and it's all overclocked :P
Posted on Sep 18, 2008
    Genius:
  • 1,067 Answers
U shoudl cheak power suply maby one bad rail or the ram
Posted on Jan 25, 2008
When I start up my HP Pavillion a6544f the monitor does not receive any signal and it remains blank. I have already tried to reset the BIOS and checked all loose cables and connections as suggested on the...
Yes, I have a LOT of information before you take it in for costly repair.
I believe you have a bad Power Supply. Weak voltage power rail.
How do I come to this conclusion?
1) Your Power Supply probably has enough power to light LED lights, and maybe spin fans, but it does NOT have enough power to turn the Processor on.
No Processor operating, No computer operating.
No computer = No Signal on the monitor. {No video signal}
A) ALL of the LED lights on at one time use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor uses 51 to 125 Watts of power. Depends on what Processor it is.
The HP Pavilion a6544f desktop computer comes with an Intel Core2 Quad Q6600,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01494006&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3757419
The Intel Core2 Quad Q6600 can use up to 105 Watts,
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors#Core_2_Quad
The Intel Core2 Quad Q6600 is a power hungry processor.
Solution?
Replace the Power Supply.
2) A bad Power Supply is one of the leading causes of computer failure.
Right behind it, is the computer is dirty inside.
(This also 'kills' Power Supply's)
The Power Supply has a Form Factor.
This refers to the size, and shape of the Power Supply's case, and the power cables coming out of the Power Supply.
The form factor for the Power Supply in an HP Pavilion a6544n is an ATX form factor.
It is a 300 Watt unit.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01324212&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3757419
The power cables needed are;
A) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Color of the connector makes no difference)
B) 4-pin ATX + 12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) Uses a SATA harddrive, and a SATA optical drive, so the Power Supply needs to have at least two SATA power cables,
(Optical drive = CD/DVD drive. If there is more than one CD/DVD drive, there needs to be more SATA power cables)
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
To be continued in an additional Comment.
Dec 22, 2010 | HP Pavilion a6544f Desktop PC
Boot up does not load to login prompt. It loops after not detecting D1.D2.D3 and goes right back to the Start Windows Mormal prompt
you will have to change the boot sequence in the BIOS.
preee F2 or Del to enter the BIOS - you can change the sequence, set the first Boot 1 = DVD/CD, boot 2 = Hard drive
press F10 exit and save > ok
next time it will iuse the DVD/CD to boot first.
if you set the boot to b1 = Hard drive & boo 2 = DVD/CD......the hard drive boots
hope this help
merry xmass
Dec 21, 2010 | RaidMax RX-450K 450W ATX12V Power Supply...
When booting my computer i only get to the windows loading and then i get the blue screen which i do not get enouhg time to read, it restarts very quick. i tried swaping hard drives and still can't get...
One bad lead will cause your computer to continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Sep 19, 2010 | Nspire NSP-450P4DL (NSP450P4DL13) 450-Watt...
Install IDE devices (drives / DVD / CDROM) sata
IDE devices have different "data" and "power" connectors than SATA drives.
So, you need a motherboard with IDE connectors, if you wish to connect an IDE disk-drive (or CD/DVD), and you need a motherboard with SATA connectors, if you wish to connect a SATA device.
Similarly, the connectors on the power-supply must be compatible with the sockets on the disk-drive (or CD/DVD) drives, so that the devices can get power.
You could possibly purchase a short IDE-to-SATA power-adapter, if you have a SATA device, but there are no SATA power-connectors on your power-supply.
May 29, 2010 | Intel Motherboard
How much is my computer worth
Based on brand new parts:
500GB SATA - $56
160GB SATA - $45
4GB RAM - $112
V-card - $105
CPU (Proc., Mobo, P/S, reader) - approx. $107
Your rig can be sold at around $425 - $450 approximately.
Hope this helps.
I had assembled a Quadcore system at around $750.
Mar 20, 2010 | Computers & Internet
Installing a new power supply unit
Nothing to worry about, there are always extra connectors for different configurations.As long as you have the 24 pin and 4 pin connected to the MoBO and your CD/DVD drives and HDD are powered you'll be OK
Jul 30, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Advice for buying a new power supply compatible with my videocard
Get a 600 watt they are better and will handle all that you need the price from a 450 W to 600W is not much I run 7 dvd's a ATI Video capture card with a 64 bit AMD processors 1 80 gig Hd 2 Sata Drives 120 gig and sound blaster audio card and more and the 600 watt does fine The Corsair is ok Where to you think your going to get it at on line? or at a store? You can buy them at
tiger direct.com or Fry's.com The 600 watt ATI power supply will have 6 standard HD connecotors and I use three Y's for more and never had any problem with mine.
Jun 05, 2009 | Computers & Internet
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Asus smps gud enough
Hi, i am struggling to understand your question 100%
but if its, is the 500watt power supply enough or good enough for the spec you have listed then yes it would work fine with the spec.
Happy New Year
John
Dec 31, 2007 | ASUS Atlas A-50GA (90PMB50A24100C1Z)...
ASUS P5PE-VM Motherboard Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
